Hello
My 2017 doesn't have a slot for the PDR function. it's not even listed on the screen like some of the videos. I also notice I don't have 2 cameras in the front of my grill. Is that something I can still get added to it?
Hello
Thank you
Do you have the 2LT interior? 1LT (like mine) don't have the PDR.
Thanks for replying
I am thinking I have the 1LT interior because I don't have the PDR information, anywhere in my owner's manual etc. I just checked online what the 1LT and 2LT looks like inside, and I am thinking I have the same one you have , the 1LT. My seats were Red, but I have since covered them with custom seat covers.
I can still do the Valet mode, which locks the screen and glove but that's about it.
He could still have it. PDR is an option that comes packaged with Nav. 3Lt has it because it has most of the options. But it sounds like he doesn’t have that option.
Check under carpet in the back on top of black foam cover over battery area.
You should see a sticker with RPO Codes for your car. Code: UQT is for Performance Data Recorder
Other codes are listed here: https://www.corvsport.com/2017-c7-corvette-rpo-codes/
1LT, 2, and 3 can have a PDR. My 2016 Stingray is a LT1 has it, as I ordered as an option. If you don't have a slot for the PDR card in the glove compartment you don't have the PDR. You won't have the NAV either.
Lt1, 2, and 3 can have a PDR. My 2016 Stingray is a LT1 has it, as I ordered as an option. If you don't have a slot for the PDR card in the glove compartment you don't have the PDR. You won't have the NAV either.
LT1 and LT2 are engines. LT2 is only in the C8 and LT3 doesn't exist.
From: SUFFIELD CT USA 2023 C8 CORVETTE UN-MODIFIED FINALIST
Originally Posted by bbrown450
No slot in glove box …no PDR…just that simple. The cameras in the grill have zero to do with the PDR camera, which is in the mirror assembly …
Not a wasted day! I just learned something! Makes perfect sense though, all those track videos I've watched couldn't have been shot from
1 foot above the ground!
