So waiting for an appt to have my LG long tube headers and x pipe installed and looking at replacing the stock npp exhist as well but wonder should i wait till i have headers done so i know how much louder they will make car i am looking forward to the extra volume as my last car had slp loudmouths on it and i miss the noise anyone else have both exhaust and headers and wanna chime in
It’s going to sound great when you’re under decent throttle pressure and scream at WOT.
When you’re at idle or cruising it will sound almost stock with the OEM NPP when the valves closed.
I have a similar setup (Corsa) and want more sound volume at idle and light throttle so I have the Corsa Extreme Variable (w/ NPP Valves) going on tonight. I’m also adding the Mild2Wild so I can keep the valves open or closed regardless of the throttle position.
why didn’t I just add the Mild2Wild or pull the fuse to have the stock NPP valves open all of the time? The drone was pretty bad cruising and sounded like crap. The Corsa will eliminate all the drone.
