Catchy Deck Lid
Old Jun 30, 2022 | 02:32 PM
Richard Ames's Avatar
Richard Ames
Default Catchy Deck Lid
2019 GS sometimes the deck lid will not release fully to open. Releases one notch but the closer pulls it back down. Spring seems OK but seems to happen if I do not open the deck for a week or so. After 5 or so tries and releasinng it works OK for a few days then does not fully release and keeps pulling the lid back down. Anyone have this happen and what was the fix?
Old Jun 30, 2022 | 02:37 PM
Jeff V.'s Avatar
Jeff V.
Try cleaning the seal that goes around the perimeter of the hatch. Make sure someone hasn't put some gooey rubber preservative or other chemical on it. The hatch may be sticking to it and it's acting like a reverse spring to pull it back down.
Old Jun 30, 2022 | 08:47 PM
Avanti's Avatar
Avanti
There have been other similar reports here. An "Advanced search" across the C7 Forums should find them. All the best. .
Old Jun 30, 2022 | 09:06 PM
Richard Ames
Searched before posting and found nothing so can you do link cleaned the seal and contact points of the seal and rubber. As suggested in first reply. Thanks
Old Jul 1, 2022 | 09:01 AM
stevettec7's Avatar
stevettec7
Even though mine doesn’t have the pull down motor, a coupe weak struts caused my hatch lid to not fully pop up when opening. Could this be your issue?
Old Jul 1, 2022 | 09:38 AM
Jeff V.'s Avatar
Jeff V.
The spring in the latch is what pushes it up in the initial inch or so of travel. The gas struts don't come into it until it's open part way. If it didn't work this way, the hatch would pop all the way open as soon as it was released.
To Catchy Deck Lid
