Road rash
Old Jul 1, 2022 | 12:45 PM
HT1663WB's Avatar
HT1663WB
Default Road rash
So I noticed on my C7 Z06, just over 12k on it, I had road rash behind the driver’s door, just below the gas door. Also on the passenger side, same area. I tried Dr. Color chip. Because my Z is Long Beach read metallic I thought for sure it wouldn’t be a perfect match. I followed the directions to a T. I was amazed at how it turned out. I included a couple pics. I did take it to a shop and they said they couldn’t do anything with it except repaint the panel. This kit cost me $60.
Before
After
Old Jul 1, 2022 | 01:03 PM
Kevin A Jones's Avatar
Kevin A Jones
Hum, I guess it depends on the color as to how close Dr Color Chip matches as I tried it on my 2018 Tacoma (Silver Sky Metallic) and the Dr Color Chip wasn't even close.
In fact, my Blade Silver touchup paint from GM matched the silver sky metallic MUCH closer. I won't try it again as it cost too much for rolling the dice for a match.
Old Jul 1, 2022 | 07:21 PM
Grand Slam's Avatar
Grand Slam
I had terrible road rash behind the wheels on my C5 but have none on my C7 which I attribute to the value of the side skirts.
Old Jul 1, 2022 | 07:25 PM
Kevin A Jones
Yep, combine side skirts along with GM mud guards and you have cut your risk for damage down considerably.
Old Jul 1, 2022 | 09:22 PM
geewez's Avatar
geewez
Common problem on the C7. My GS comes with the side skirts and fender lips but I still got sand blasted in the same area from road debris kicked up by the tires. Here's what I did to eliminate the problem. Had Expel install to cover that area and replaced the factory fender lips with the ACS Composite XL fender lips and XL rock guards. Expensive way of doing it but no more issues.
Old Jul 1, 2022 | 09:28 PM
DALE#3's Avatar
DALE#3
VERY INTERESTING...
Could you please explain what a FENDER LIP is?
Old Jul 1, 2022 | 11:22 PM
Looks like a good job on the touch up.
Old Jul 2, 2022 | 01:11 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
You did a nice job!
Old Jul 2, 2022 | 10:29 AM
1bdvet's Avatar
1bdvet
U.S. Air Force
St. Jude Donor '05 thru '26
Nice job!
Old Jul 2, 2022 | 11:34 AM
ZO6LIFE's Avatar
ZO6LIFE
Before
After
I have the same exact car with the same issue. Even have 3 spots on the front. I'm going to get it painted and follow up with protective flim by my detailer. Do it once, do it right. But yours came out pretty impressive for a touch up job. Very nice.
Old Jul 2, 2022 | 08:16 PM
wrecker3's Avatar
wrecker3
Dump the Rock Throwing Pilot Sport Tires.
Old Jul 2, 2022 | 11:07 PM
Elk's Avatar
Elk
If you prefer a lower performance tire, run it.
Old Jul 3, 2022 | 06:28 AM
449er's Avatar
449er
CF Community Team
lol
Old Jul 4, 2022 | 10:41 AM
HT1663WB's Avatar
HT1663WB
I have the full lenght side skirts and the gm extended guards and it still happened.
Old Jul 4, 2022 | 10:51 AM
LT4CMG's Avatar
LT4CMG
Xpel. Has never failed me since 2013.
Old Jul 4, 2022 | 11:04 AM
Kevin A Jones
Had the protective PPF that comes from the factory on that panel been removed?
Old Jul 4, 2022 | 11:42 AM
Red08's Avatar
Red08
I installed both the splash guards and put on side skirts to reduce/eliminate road rash and they definitely help. Very little road rash seen.
Old Jul 4, 2022 | 03:55 PM
HT1663WB's Avatar
HT1663WB
No, the damage on mine was just below the gas door. I circled the area. Both sides had it.
To Road rash
