Has anyone ever come across there TPMS sensor shutting there car off while driving it? It has happened to me 3 times now and now my car won’t even start. On my dash it’s saying unable to locate tires. I replaced the battery in the car an drove it around thinking that was the problem but now it’s doing it again. The 1st two times it happened it wasn’t showing my tire pressure’s so I reset them. This time it’s showing all 4 pressures but it’s still not locating my tires an the car won’t start. Frustrating!!
I had a tpms fail on my 2014 that I used to own. It was only one wheel failed.
Did not shut car off just showed the tire warning icon.
If your car can’t find the tires, that sounds more like a system failure.
I doubt all 4 tpms would fail at the same time
The car will operate just fine without any tire pressure sensors. Can you post a photo of the actual message? Any chance you have access to a scan tool that will read the BCM codes?
Edit: Can you lock and unlock the doors using the fob?
Since none of the four Tire Pressure Monitors are being monitored, it's not impossible that all four can fail simultaneously, but more likely that all four are transmitting. Therefore, I'd look at the Wireless Control Module. It could be failing or you may have another component failure that is affecting the WCM.
The pressure monitors are stupid. They just broadcast a signal. The Wireless Control Module grabs the four signals and passes that data along the GMLAN to the Body Control Module.
Last year when I changed my tires and wheels, I also installed new pressure monitors. I was told it may take a few miles for them to register. They actually registered immediately. I do not believe the loss of tire pressure should fail the start circuit.
This is certainly not what we like to hear, bgphillystyle. Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your vehicle. To do so, please send an email to socialmedia@gm.com with ATTN: bgphillystyle/Corvette Forums in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information. www.gm.com
