Advice on Diff fluid
Old Aug 1, 2022 | 12:28 PM
pifo1964's Avatar
pifo1964
Default Advice on Diff fluid
Hello everyone
I am going to change the differential fluid on my 2016 Z51.
On my previous Corvettes I used to use Castrol Syntrac 75W90 100% synthetic, but I just talked to the Castrol dealer and they say they haven't had it for a few months now and they don't know when they're going to bring it back.
There are several brands here that have the limited slip additive, but the only two 100% synthetic products that I find, are Valvoline Synpower 75W90 and Motul Gear LS 75W90.
Has anyone used any of them?
What would be your preference?
Thanks!!
Old Aug 1, 2022 | 12:43 PM
ersatz928's Avatar
ersatz928
GM LS Gear Oil 75W-90, part number 10-4034 / 88862624, which I believe is 100% synthetic.
Old Aug 1, 2022 | 01:05 PM
pifo1964's Avatar
pifo1964
That fluid is not available here, I don´t live in US
I must choose between the mentioned
Thanks anyway!!
Old Aug 1, 2022 | 06:45 PM
dcova's Avatar
dcova
The Mobile 1 Synthetic Gear Oil 75W-90 meets specs. I purchased at local auto parts store. In my town it was OReilly.
If the Motul Gear LS 75W90 includes limited slip, it should meet specs
Old Aug 2, 2022 | 07:16 AM
mdformula350's Avatar
mdformula350
I dont think you can go wrong with either, as long as correct weight and has the limited slip friction modifier.. I would go with cheapest since usually its not cheap anyway.
Just buy enough to fill it up to the top.
Old Aug 2, 2022 | 09:31 AM
Jaykoh-Z51's Avatar
Jaykoh-Z51
Pifo, can you order it online and have it delivered? I've done that with a few other fluids...but I do live in the US. I don't know what the extra cost would be to your location in Uruguay.
Old Aug 2, 2022 | 10:30 AM
pifo1964's Avatar
pifo1964
Thanks for the advice Jaykoh, but bringing lubricants to the country is very complicated if not impossible, I have to carry out countless procedures that end up being very expensive, in addition to the time it takes.
The regulation in Uruguay says that as a person, I can bring anything from overseas; up to $200 per shipment (max 6 per year), I do not pay taxes and for more than that amount, an extra expense of 60% is paid. Also,I can bring up to $1,000 with me if I return from a trip, and as I travell twice a year to the US, is not a problem to get parts for my Corvette. But that same regulation prohibits me from bringing lubricants, fuel, tires, medications, cosmetics and some other products.
Best regards!!
Old Aug 2, 2022 | 02:52 PM
Avanti's Avatar
Avanti
Essentially, the only thing that really matters is the Limited Slip Modifier. Otherwise, it's which bottle you prefer.
Old Aug 2, 2022 | 05:11 PM
Red08's Avatar
Red08
I changed the diff fluid in my 2014 with Z51. I used the recommended AC Delco fluid. No problems.
Old Aug 2, 2022 | 06:10 PM
need-for-speed's Avatar
need-for-speed
CI 1-4-5-8-9-10 Vet
St. Jude Donor '03 thru '10, '17
yep. Pick one of those 2, and you’re good to go. I would say pick Valvoline, but someone will come on here and tell how they use Motul in their diff and never blew up lol.
To Advice on Diff fluid
