Anyone ever have there air condition turn on by itself when all you want is outside air? Mine randomly does this. Itll be just outside air for a few and then the air conditioner will kick on. Its not on auto mode either. Is there a setting for this? Aggravating when its a cool 68 degree morning and all you want is outside air through the vents but the air kicks on.
are you sure it's in full manual mode?
I only ask because I know these stupid units in cars nowadays almost have 3 modes, Auto, Half Auto and Manual.
I've found that when it's in Full Auto you have to select several things yourself to get it all the way in manual.
Like first turn Off the AC, but then also select a different air source or a different vent location.
Also be sure it's in SYNC and not dual climate bs
This feature will set the auto fan speed. Select Low, Medium, or High.
Auto Defog
When set to On, the front defog will automatically react to temperature
and humidity conditions that may cause fogging.
Select Off or On.
Auto Rear Defog
If equipped, this feature will automatically turn on the rear defog.
Select Off or On.
Ron
i turned that off this morning but itd still turn the air conditioner on if i set the temp to low. Guess ill just have to turn it up a notch from low to keep it from doing this.
My car is doing the same thing and driving me nuts. Appears AC is completely off, but then blows cold, even at 55 degrees this AM. Curious if there are any additional ideas of how to resolve this.
never figured mine out. Only does it like you said, when its cool out. On a very hot day if its set to LO its just the outside air. I just turn mine up to where it displays degrees instead of just LO. Then its only the outside air coming in.
