C7 exhaust difference
Old Sep 14, 2022 | 09:56 PM
Stephen Sims's Avatar
Stephen Sims
7th Gear
Default C7 exhaust difference
My outside exhaust tips are way darker than the insides. I have a range device so it's never in 4 cyl mode. Is it normal?
Old Sep 14, 2022 | 10:08 PM
Buddhaman's Avatar
Buddhaman
Do you have the NPP exhaust? If so then that's pretty normal since the outside pipes bypass some of the muffler. If you have the standard exhaust then somethings odd since they only have 1 outlet from the muffler to the two tips.
Old Sep 14, 2022 | 10:19 PM
Kevin A Jones's Avatar
Kevin A Jones
You probably have NPP exhaust, where it would be normal as the diagram below indicates.
Old Sep 14, 2022 | 10:20 PM
LT4CMG's Avatar
LT4CMG
Looking at the pic in your avatar, it's doing exactly what it's supposed to do OP. No worries
Old Sep 14, 2022 | 10:41 PM
I have the NPP exhaust and the outside tips always require more cleaning than the inside ones do. I'd say yours is normal.
To C7 exhaust difference
