I remember when engine and trans mounts just were rubber molder around metal. I bought aftermarket ones that were stiffer with polyurethane back on my 91 and 01 firebirds, even had options for solid mounts. now fluid filled ones..
sounds just like the belt tensioner when you see it wet with oil, its usually leaking and time to replace.
The mounts use oil as a dampening agent. If it is leaking it needs to be replaced
Engine mounts are filled with oil but i dont think the trans mount is ...
OP have somebody put it up on a lift , could be something simple as the fill plug is loose ..... or the pan bolts are loose
Dave
I suppose I could be wrong, but it looks like a fluid filled mount to me at casual glance.
OP let me know if you need these will give you two good ones from my 2014 if they are the same. I went to solid set up in my c7. Just pay for the shipping. Robert
