squeaking top
Old Sep 19, 2022 | 11:32 AM
Stop Flop's Avatar
Stop Flop
Supporting Vendor
Default squeaking top
The removable top on my 2014 Z51 c7 makes a annoying rubbing noise when i go over bumps. Seems to be coming some where near the mid front area. Anyone else have the problem?
dave
Old Sep 19, 2022 | 01:21 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
Try putting Silicone on all the rubber molding and roof contact areas. It worked for me.
Old Sep 19, 2022 | 02:13 PM
Stop Flop's Avatar
Stop Flop
Supporting Vendor
I found the problem, my head liner is coming off and the glue is sticking and not sticking causing the sound.
Old Sep 20, 2022 | 09:43 AM
A little lubrication on the weatherstripping can do wonders for squeaks.
Old Sep 22, 2022 | 01:48 AM
Avanti's Avatar
Avanti
You are fortunate to have corrected it so easily. There are a gazillion threads here with top noises, along with a multitude of "fixes."
Old Sep 22, 2022 | 09:56 PM
wgood's Avatar
wgood
I have the same year vette also Z-51 and I really think the squeaking is coming from the insulation inside the removable top and pushing on the covering sounds like bubble wrap !!!!! I have thought of taking the top to an interior shop and replacing it with something else !!!
Old Sep 23, 2022 | 06:42 PM
Richard562's Avatar
Richard562
Navigator
Default Squeaking fix
I had this problem on my 2014. I tried all the lubricant and grease solutions nothing worked. I took it to the dealer and they replaced the strikers and pins. This solved the problem but cost around $500.
Old Sep 24, 2022 | 03:31 PM
jimmbbo's Avatar
jimmbbo
I solved the top squeaking by cleaning the rubber seal and applying three coats of 303 Rubber Seal Protectant per the video below.
I found the silicone goo to be difficult to work with as it gets on places it wasn't intended to as it goes on "wet", while the 303 dries before installation. With the grease, accurately seating the top on the first attempt was not consitently possible, leaving smears of silicone behind…
I redo the process every six months and have been squeak free for nearly three years
https://smile.amazon.com/gp/product/...e?ie=UTF8&th=1
To squeaking top
