My passenger side headlight is fluttering. I did a search and some people have reported this problem in the past but with no real solutions. I have had several HID equipped vehicles and none have had this problem. Drivers side seems fine. Its extremely annoying seeing street signs flickering in the distance and its distracting.... cant imagine what it looks like from head on traffic. Has anyone found a solution for this, or am I gonna have to buy a new headlight?
I have no idea since I never looked at how the whole lamp unit is fastened in place. Could one or more of any fasteners be loose that holds lamp reflector or such be loose? Just spitballing. Another thought, does it flicker in conjunction with pavement ripples or in a completely random way?🤫
I haven't taken bumper off to check tabs yet but the headlight assembly seems solid just pushing on it from the outside. If I pull up behind a truck or suv at a light... I can see the fluttering sitting still sometimes.
Have not heard of this symptom before. Could be as simple as a loose connection. It could be the ballast. The bulb usually works or is fully out. Keep us posted.
This problem has been noted since the C7 came out. Flip the headlights to high beam and back. There is a shutter that moves inside the light. Maybe some exercise will solve the problem.
Headlights are sealed units and the bulbs are not easily replaceable. The whole bumper panel needs to come off for access.
This is certainly not what we like to hear, euby. Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your vehicle. To do so, please send an email to socialmedia@gm.com with ATTN: euby/Corvette Forums in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information. www.gm.com
I've had this issue before. HID bulb is failing and needs to be replaced. Job is not as bad as it sounds, but the front bumper cover has to come off. If you do it yourself be sure to put blue masking tape along all of the edges to avoid scratching the paint.
