X-pipe emissions
Old Sep 24, 2022 | 09:12 AM
CorvetteBacon's Avatar
CorvetteBacon
Default X-pipe emissions
Searched this and can’t find definitive answer. Just purchased a 2014 from Pennsylvania and live in New York. Car has a catless x-pipe. Does anyone know if it will pass NY state emissions? I do have the stock x-pipe with cats if need be.
Old Sep 24, 2022 | 09:41 AM
BAT's Avatar
BAT
2026 Corvette of the Year Finalist - Modified
2025 C7 of the Year Winner - Modified
2024 C7 of the Year Finalist - Modified
2023 C7 of the Year Finalist - Modified
2021 C7 of the Year FinalistAX - Modified
It should be fine. Catless x pipe eliminates the secondary cats only, not the primary cats. Although I'm not in NY, mine passed Massachusetts and Connecticut emissions with an AWE off-road (catless) x pipe.
Old Sep 24, 2022 | 10:40 AM
Maxpowers's Avatar
Maxpowers
Unless NY does not physically inspect the existence of the secondary cats....you will be good. If you have NPP....put it in stealth mode.
Old Sep 24, 2022 | 10:00 PM
I guess it is worth a try - if it passes, great, if not, put the stock system back on.
Old Sep 25, 2022 | 07:17 AM
449er's Avatar
449er
CF Community Team
Like Maxpowers stated, If New York does an actual visual inspection, you will fail
Old Sep 25, 2022 | 08:35 AM
CorvetteBacon
That’s exactly what I was thinking. Stealth mode and I believe they put probe for exhaust in tail pipe so I will be there and tell them to put probe in outside tailpipe because that one has a scratch and don’t want the others to get one!!! 😉😉 Thanks for responses but hoping a fellow NY guy will chime in.
Old Sep 25, 2022 | 09:09 AM
96GS#007's Avatar
96GS#007
Unlikely they test the emissions. They'll plug into the OBD II port, check for codes, verify all the monitors are set, do a quick visual, and send you on your way.
On a C7, it's next to impossible to tell if the factory mid-pipe has been replaced with one that has no cats unless you put the car up on a lift.
In the VERY unlikely event they do test for emissions, they'll put the probe into one of the center pipes with out the NPP valves. If you have it in Stealth or Tour mode for example, the valves for the outer pipes will be closed and they'll be unable to insert the emissions probe.
Old Sep 25, 2022 | 01:52 PM
MITCH's Avatar
MITCH
I have the AWE x pipe and live in NY and have had it on the car for 2 years. No problem at all.
enjoy.
Mitch
To X-pipe emissions
