TPMS/battery question
Old Sep 26, 2022 | 09:06 AM
Catfish4818's Avatar
Catfish4818
Default TPMS/battery question
I'll be putting new tires on our 2015 in a few months. At that time, is it recommended to replace the pressure sensors in each wheel? Or do the sensors have a battery that is replaced?
TIA,
Larry
Old Sep 26, 2022 | 09:20 AM
Maxpowers's Avatar
Maxpowers
The battery cant be replaced. I dont recall many threads on dead batteries (or even one?). The TPMS in my 13 year old SUV still has the original sensors.
Old Sep 26, 2022 | 10:01 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
My 2014 sensors are still working in my car. When I change my next set of tires, or if one craps out before, I'll replace the OEM sensors with new ones.
Elmer
Old Sep 26, 2022 | 11:29 AM
orca1946's Avatar
orca1946
My 2006 Z51 went 13 years and were still working fine!!!!
Old Sep 26, 2022 | 11:41 AM
Widgeon5's Avatar
Widgeon5
TIA,
Larry
The battery is not meant to be replaceable, however there is a video somewhere on Youtube showing how to do it, at least for one brand. Quite tedious and complicated; requires breaking glued seals, soldering and regluing. New ones are in the $40 range, I wouldn't consider it remotely worth the time and effort.
Old Sep 26, 2022 | 01:54 PM
DTOM's Avatar
DTOM
C7 of Year Finalist (performance mods) 2019
I'd replace them. They are already near their projected life span
Old Sep 26, 2022 | 11:04 PM
If it were my car, I would go ahead and just replace them - consider it preventative maintenance.
Old Sep 29, 2022 | 12:43 AM
squirrelchew's Avatar
squirrelchew
TPMS sensors have batteries that last between 7 and 15 years. A shop with proper tooling should be able to read out the battery life of most sensors and recommend replacement accordingly. This can be done with the wheels on the car and everything.
Worst case scenario you take the gamble and a TPMS sensor dies before your tires wear out. You buy a new sensor, and pay for a dismount+remount of your tire -- so like $70.
Old Sep 29, 2022 | 06:24 AM
mdformula350's Avatar
mdformula350
must have energizer batteries
but yeah id had a tpms sensor physically fall apart before the battery went.
Old Sep 29, 2022 | 10:01 AM
ICONIC7's Avatar
ICONIC7
2025 C7 of the Year Finalist - Modified
2023 C7 of the Year Finalist - Modified
I'm putting new rims and tires on mine and decided to put new TPMS on just so everything is brand new.
Old Sep 29, 2022 | 11:03 AM
jaki30's Avatar
jaki30
The tire(s) do not have to be dismounted and re-mounted to replace a TPMS sensor.
Only the bead needs to be broken on the TPMS side of the tire and the sensor can be replaced.
If they mark the tire, you won't even need a re-balance.
Had a sensor on a 2014 I owned replaced by the dealer years ago.
Old Sep 29, 2022 | 11:06 AM
Maxpowers's Avatar
Maxpowers
There are two new TPMS sensors in the for sale section. Good price.
Old Sep 29, 2022 | 06:10 PM
Harvey White's Avatar
Harvey White
I just replaced the tires on my 2014 that I purchased new in October 2013. I also had the TPS sensors replaced as well as they were 9 years old.
Old Sep 30, 2022 | 08:20 AM
Zaridef's Avatar
Zaridef
Replacing the battery is too cumbersome and prone to problems. If it really needs to be replaced, it is better to find a professional person to help. As for the TPMS sensor, it should continue to work, if it's not too old.
Old Sep 30, 2022 | 09:34 AM
Mad*Max's Avatar
Mad*Max
TIA,
Larry
Do you have a lot of miles on the car? The less it is driven, the longer the sensors are asleep meaning longer life span.
Old Sep 30, 2022 | 12:12 PM
Catfish4818
Good point. Currently has 18,000 miles. Bought in December with 13,000. Looks like I'm having more fun with it than the two previous owners.
Old Sep 30, 2022 | 01:15 PM
Mad*Max's Avatar
Mad*Max
Personally I would leave them be as they can be changed out one by one without removing the tire from the wheel.
To TPMS/battery question
Old Nov 17, 2022 | 10:06 PM
JMoore5196's Avatar
JMoore5196
As usual, contributors to this thread offer sage guidance! I hope no one will mind if I resurrect the topic.
Last September, I had 3 TPMS sensors play up during a long-distance drive. I do not have LED side marker lights installed. The guidance from members here was to replace all 4. One member offered a well-known eBay vendor as a reasonably-priced sensor source. My local dealer did the install.
Fast forward 15 months and 5000 miles, and my two front sensors dropped out during a drive this afternoon. Before I spend the money to replace them again, I’m compelled to ask: If typical sensors should last a decade or so, is there any other cause to which I might attribute this most recent failure?
Thanks in advance!
Old Nov 18, 2022 | 05:22 PM
RacerRik's Avatar
RacerRik
I bought new GM OEM sensors from a seller on ebay. One of them has died already in less than two years. I replaced it with a Schrader sensor from Rock Auto. I have more confidence that Rock Auto is selling me good sensors vs some ebay seller that may have sold me counterfeit parts that do not last. The Schrader 20223 part is exactly the same as the GM OEM 13598775 part.
Old Nov 19, 2022 | 01:12 PM
76-Vetteman's Avatar
76-Vetteman
The GM OEM TPMS sensors made it on my Yukon Denali for over ten years. I had them (OEM) replaced three years ago and they are still going strong.
Last year I purchased four new TPMS sensors from Rock Auto for a second set of C7 wheels; except, they were ACDELCO OEM, #13598775. So when I dropped them off at the local Discount Tire store with the wheels, I learned quickly that the ACDELCO EOM sensors were not shipped with the stem seal locking nuts. Discount Tire to the rescue, they had stem seal locknuts that would fit and seal properly.
When I ordered the TPMS sensors from Rock Auto, I foolishly did not notice that the OEM sensors did not come with stem seal lock nuts. Later I learned the stem seal lock nuts are not available from Rock Auto, still to this day, and at the time they were not available from GM either!!
Good advice from @RacerRik, the SCHRADER TPMS sensors from Rock Auto should work just fine and the batteries should provide a long service life. Yes, they come complete with the stem seal lock nuts.
