Lug Nuts
Old Sep 28, 2022 | 09:14 AM
the blur's Avatar
the blur
Default Lug Nuts
I need lug nuts for my GS. The OEM lug nuts can't take the abuse of an impact gun. The caps are already dented, coming loose.
Who makes a good 1 piece lug nut ?
Old Sep 28, 2022 | 09:54 AM
EVRGRN's Avatar
EVRGRN
Amazon.com: CASOMAN 1/2- Inch Drive Wheel Protector Impact Socket, 1/2" Thin Wall Deep Impact Socket Set Plastic Sleeve Lug Nut, 4 Pieces Set, 6 Point,Metric, 17mm,19mm,21mm,22mm : Tools & Home Improvement Amazon.com: CASOMAN 1/2- Inch Drive Wheel Protector Impact Socket, 1/2" Thin Wall Deep Impact Socket Set Plastic Sleeve Lug Nut, 4 Pieces Set, 6 Point,Metric, 17mm,19mm,21mm,22mm : Tools & Home Improvement
Then buy a set of McGard lugs to replace the OEM lugs.
Old Sep 28, 2022 | 10:05 AM
Jmhornz71's Avatar
Jmhornz71
I bought some solid lug nuts from Zip Corvettes and they are doing great
Old Sep 28, 2022 | 12:05 PM
DTOM's Avatar
DTOM
C7 of Year Finalist (performance mods) 2019
McGard.
Old Sep 28, 2022 | 12:34 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Do those sockets have a non-marring surface on the inside?
Otherwise, I think they'd only protect the wheel where it's near the nut, not the nut itself.
Also, if you use a clean/smooth socket that fits the nut tightly, wouldn't that be just as good?
The Corvette tech at our dealership says the problem comes from sockets that are a bit loose, so the force gets applied to mostly the angled edges of the socket and distorts them.
I switched out the nuts on our C6 at about 50k miles because they were getting a bit distorted, but that's just me swapping wheels around using cheapo sockets.
Looking for an education here...
Old Sep 28, 2022 | 01:12 PM
jimmie jam's Avatar
jimmie jam
I've been using these that i bought at HF. Worth every penny at twice the price IMSO.
Old Sep 28, 2022 | 01:26 PM
RMS73's Avatar
RMS73
I use the plastic lined sockets. The correct method to removing the lug nuts is to keep the socket tight to the base of the lug nut so the socket won't impact the nut in the tapered area causing a loose fit and higher than normal force on the nut sides.
Old Sep 28, 2022 | 01:55 PM
EVRGRN's Avatar
EVRGRN
From the item description, the lugs and wheels are both protected:
  • 360° Non-scratch Nylon sleeve and insert protect bolt tops, wheel rims, and lug nuts from scratches during use
I've not used these myself, but they look to be a good option to consider for the OP.
Old Sep 28, 2022 | 06:54 PM
vettetwo's Avatar
vettetwo
Could not see an internal plastic sleeve. The pictures do not give a very good view inside, but the end which is visible do not have any protection. Perhaps someone who has purchased these can comment, but my opinion is they are metal on the inside. I have a 19mm and 22mm that look like these with the name Titan on the band. They are plastic on the outside to protect the wheel, but no protection inside.
Old Sep 28, 2022 | 07:14 PM
jimmie jam's Avatar
jimmie jam
Originally Posted by vettetwo
Could not see an internal plastic sleeve. no protection inside.
They are not metal, nylon inside also.
Old Sep 28, 2022 | 07:53 PM
McGard makes some excellent lug nuts.
Old Sep 28, 2022 | 09:39 PM
geewez's Avatar
geewez
Most auto manufacturers use a lug nut with a chrome cover over it which is what usually twists and dents. Upgrade to a set of McGard Tough Nuts. They're a solid, triple chromed, lug nut with a lifetime guarantee.
Old Sep 29, 2022 | 07:49 AM
NashvilleGrandSport's Avatar
NashvilleGrandSport
I had Discount Tire replace mine when I had my Cray wheels mounted. Got rid of the OEM junk.
Old Sep 29, 2022 | 09:51 AM
ICONIC7's Avatar
ICONIC7
2025 C7 of the Year Finalist - Modified
2023 C7 of the Year Finalist - Modified
I've done research on this and came up with McGard and Gorilla as the top 2 options
Old Sep 29, 2022 | 01:05 PM
Gearhead Jim
St. Jude Donor '13
I recall seeing a thread here years ago, where someone posted that one of the popular brands of aftermarket nuts has a cone angle, or whatever you call it, that's different from the stock nuts and the angle in the stock wheels where the nut seats.
Any information?
Old Sep 29, 2022 | 04:46 PM
Joe C5 C2's Avatar
Joe C5 C2
If you want to really protect the finish of the nut itself this is what you need. I have had one for years and works perfect.
https://www.vertexauto.com/porsche-l...l-p-12314.aspx
To Lug Nuts
