Badge Changing
Old Sep 28, 2022 | 03:25 PM
BWF07's Avatar
BWF07
St. Jude Donor '11
Oldtimer
Default Badge Changing
I would love to replace my chrome badges with the carbon flash badges and was wondering if anyone has changed theirs and what all is involved.
Old Sep 28, 2022 | 03:47 PM
Maxpowers's Avatar
Maxpowers
Many have. Ive seen some write-ups here. I removed some badges. A liitle heat to pull off and goo gone to get the adhesive off. It takes some elbow grease.
Old Sep 28, 2022 | 03:53 PM
clusterone's Avatar
clusterone
Fishing line to remove the original, use like a saw. Braided line works best. Then just remove left over adhesive with WD40 and fingers. Might tape off area around badge with frog tape. Good luck!
Old Sep 28, 2022 | 06:31 PM
Jbyrd43's Avatar
Jbyrd43
I did mine and it was fairly simple. Fishing line or dental floss for sure. Put masking tape a the bottom
of the emblems (stingray, corvette words) to line them up the same.
Old Sep 28, 2022 | 07:39 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
Make a pre - removal template of the Stingray emblem and Corvette lettering if you are replacing them too. Makes replacement much easier.
Old Sep 28, 2022 | 07:58 PM
Just take your time and all will be good.
Old Sep 29, 2022 | 11:15 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
You can use a mild mineral spirits as well, using a syringe to get it under badge before you begin, only hair dryer not heat gun. Tape off area (just in case) and be patient as stated above. Stay away from strong solvents like acetone
Old Sep 30, 2022 | 09:20 AM
Zeek's Avatar
Zeek
St. Jude Donor '07, '11 thru '24
Official Sponsor of the 60 Day VacatioNN
10,000 poster in the "thread" Part II
Easy peasy....fishing line or dental floss to remove (a little easier if you let it sit in the sun or use heat gun) A rag and then some alcohol to remove remaining glue. I used my fingernail to help scrape off the stubborn glue. Then just peel and stick! I went with the black emblems.
Old Sep 30, 2022 | 03:05 PM
c5arlen's Avatar
c5arlen
Oh goodness!... Now what?
Old Sep 30, 2022 | 03:28 PM
clusterone's Avatar
clusterone
On the subject...been on the hunt for these for a C7 (see pic). Southercarpart, Ecklers, and RPI all show as discontinued. Anyone know where I can get my hand on a set? Would prefer new badges, but inlays would work. Did see another American Flag option out there, but it is not near as sharp looking.
Old Oct 1, 2022 | 12:19 AM
Avanti's Avatar
Avanti
You now know more than you'll ever need to remove your old emblems. Leave them off except for the main front and rear (because they fit into indentations.) All the best.
Old Oct 1, 2022 | 06:26 AM
Catfish4818's Avatar
Catfish4818
After they're off, replace them with Ferrari emblems.
To Badge Changing
