Rattles
Old Oct 7, 2022 | 09:34 AM
64Dr's Avatar
64Dr
5th Gear
Default Rattles
2019 GS rattle in passenger door region at highway speeds. Any suggestions?
Old Oct 7, 2022 | 10:02 AM
You can take the inside door panel off, have someone drive and you sit in the passenger seat and listen for any rattles. Other than that, take it to a dealer and let them see if they can find the source of the rattle. Good luck - rattles can be a real PITA to find and fix.
Old Oct 7, 2022 | 02:53 PM
Kevin A Jones's Avatar
Kevin A Jones
Sure it's not the passenger side seat belt buckle knocking around?
Old Oct 7, 2022 | 05:12 PM
64Dr's Avatar
64Dr
5th Gear
Thanks for the recommendations.
Old Oct 7, 2022 | 06:19 PM
Raidercop's Avatar
Raidercop
My "rattle/squeak" was the top of my passenger seat leather rubbing on the B pillar. I just moved seat up a tiny bit...problem solved. Hope yours is that easy
Old Oct 8, 2022 | 08:09 AM
Maxpowers's Avatar
Maxpowers
This solved it for me a while back.
Old Oct 8, 2022 | 02:28 PM
64Dr's Avatar
64Dr
5th Gear
Thanks for the suggestion.
Old Oct 9, 2022 | 09:42 PM
Avanti's Avatar
Avanti
As stated, get someone with GOOD hearing to help. You drive and let them try to localize it Someone who is small and agile to be able to scrunch around for access is helpful. Tell them to press wherever the source seems to be. Sometimes doing so will change the sound enough to locate it. A mechanic's stethoscope can often be a help in a pinch.
Old Oct 10, 2022 | 09:20 AM
64Dr's Avatar
64Dr
5th Gear
Default Rattles
Thanks for the recommendation. I've tried all other suggestions except pulling the door panel. The stethoscope is a good idea.
To Rattles
