DIY Ceramic Coating a C7
Now let me be upfront - the paint correction steps MUST be done before applying this Ceramic coating. You MUST remove as many of the imperfections in your paint as possible otherwise this Ceramic coating will only exaggerate those imperfections even more. Let me also say, that its time consuming. I worked on my Vette over a 3 day period - several hours each day. So if you're not willing to put the time into compounding, polishing, and surface prepping - than this Ceramic product is not for you.
STEP #1: Wash & Clay - Of course before starting any work on your paint, the car needs to be fully washed. I suggest using a power washer and a foam cannon. It cleans the car while reducing the amount of surface scratching. Once clean - you MUST remove all the surface contaminants in your paint. Even if your paint "looks" great - if you rub your hand over the paint and you can "hear" your hand moving...then it needs to be clayed.
STEP #2: Compound - To get your clear coat to look new, you must remove the top layers of scratches, swirls and haze we all have on cars. FYI - Car washes cause more damage to your clear coat than driving in snow and rain. I use Adam's Compound (its blue) and works great on all surfaces. I strongly suggest you invest in a DA Polisher - you can get a really good one for $100 at any Harbor Freight. They also sell pads. They offer Course (for removing alot of swirls and scratches), Medium (for normal wear), Fine (for lite wear) and Finishing (for waxes and polishes). For 90% of you, I would get a Medium pad and a Polishing Pad unless you know your paint is really bad. Apply (4) dime-size drops on the Medium pad, set your polisher to #4 speed and SLOWLY move up & down then side to side 3 to 4 times. Let the polisher do the work - not alot of downward pressure on the polisher. Work on a 3ft by 3ft square - then move to the next section, put (4) more drops on the pad and continue. Make sure you use a plush/soft microfiber towel to remove the compound.
STEP #3: Polish - When you use Compound on your paint, it actually uses an abrasive liquid that basically (safely) "sands" your clear coat. So to now get back the ultimate shine, you need to polish your paint. I use Adam's Polish (its white) and you would now use a Polish pad. Again, (4) dime-size drop on the pad - working in the same pattern but you don't have to go as slow with polish (but don't rush it either). Working a 3ft x 3ft section, then wiping off with a plush/soft microfiber towel.
STEP #4: Surface Prep - You've done all this work to get your paint ready for the Ceramic coating, but don't forget...you have left behind alot of dust and finger prints or elbow impressions. You need to remove them or you will ceramic over them and will be seen. I use Adam's Surface Prep - its actually distilled water and rubbing alcohol. This will remove any grease, finger prints, etc.
STEP #5: Ceramic Coating - Ok believe or not - this is the easy step in this entire process but you have to take your time. To apply, you allow several drops of the Ceramic to fall into a suede block applicator (included in the kit) and work a 3f x 3ft section. Wipe the Ceramic coating around the section (almost making a border) and then wipe inside that border - this will ensure you don't miss any section. You will notice that the ceramic coating will start to "rainbow". That means the ceramic is bonding with your paint. When you notice the "rainbow" starting to fade, its time to wipe that section with suede utility towel (included in the kit) to level the ceramic and then use the plush buffing towel (included in the kit) to buff the area to an amazing shine. It will require several wipes to get all the ceramic off - take your time because you don't want to leave any behind. Make sure you work on one section of the car at a time (from start to finish). In other words, work on the hood first and don't work on any other section until the hood is complete finished (ceramic coated and wiped down).
Here is a link to the kit (don't forget to use whatever coupon code they are offering - it changes often): https://adamspolishes.com/collection...39450748092513
Hopefully this helps you with getting your car to look amazing - below are pictures of the final result - you be the judge if you think ceramic coating is something you want to do.
I used Lake Country pads, the Orange was barely needed on my 19, so after a test panel I went solely to the White. Car had about 500 mi on it so it hadn't seen much yet, however they clay already pulled out quite a bit. I used Jescar polishes, then Kamikaze coatings.
I just bought the car and it has swirl marks and I'm guess hasn't had much TLC by the way of detailing.
But yeah, price is a bit steep I might just polish and clay bar first and see how it goes.
2007 Ceramic Coated
2015 Waxed
