If the oil pressure sensor goes bad it will prevent the engine form starting to protect the engine. There are dozens of things that it could be, need to dive into a full diagnostics. Anything from a busted sensor wire to a failed oil pump or spun bearings, and lots of stuff in between. Sounds like you need a quality Technician to take a look. Here's hoping it's something cheap and easy!!
The thing that worries me most is that the engine runs as if idling.
Initially I thought I had broken the chain between the crankshaft and cam.
Last week traveling on the highway the display was showing "speed or power reduction" I don't remember well.
The car stopped due to inertia.
Once stopped a new message appeared on the display "turn off engine" and the red oil light came on. Turned off immediately.
My Corvette never came on again.
The engine once revved to start seems to run in a mild mode (almost no compression)
I disassembled the valve cover and apparently everything works properly.
During the problem I saw no smoke or heard any strange noises.
Does anyone know what could be the problem?
This is certainly not what we like to hear, Murdy1984. Please know, customer satisfaction is extremely important to us. Our team would be more than happy to take a closer look into the concerns with your vehicle. To do so, please send an email to socialmedia@gm.com with ATTN: Murdy1984/Corvette Forums in the subject line.
Please include your contact information, VIN, a brief description of your concern, and the name of your preferred dealership. We look forward to hearing from you. To learn more about GM’s privacy policy, please visit https://www.gm.com/privacy-statement.html.
Privacy Statement | General Motors
Your privacy is important to General Motors. This Privacy Statement addresses the personal information GM collects and how GM handles that personal information. www.gm.com
