Does anyone else have issues with their infotainment system? Sometimes I have issues connecting to my Apple carplay. The music plays off my phone instead of the car or im on the main screen and it wont switch over to Carplay. Is this a common problem or is it just me? 🤷🏻♂️
Yeah, these little annoyances happen occasionally. First, if the music from the iPhone starts playing, I just hit mute (because I want to listen to the sound of the car ) but you can also go to the home screen and press "AUDIO" and select what source you want. As for your second problem, there are 2 possibilities; First, if you are not using an official Apple cord, this might be causing connection problems. Many in this forum have noted that. Second, look at your phone itself and see if you have the “Unlock iPhone to Use Accessories” notification. Unlock the phone and you should be fine. Yesterday this happened to me and even after I unlocked, it didn't connect and I had to unplug the cord and plug it back in for it to work. Gremlins.....
