Check This Out Help
Old Nov 2, 2022 | 06:30 PM
Walter Raulerson's Avatar
Walter Raulerson
Default Check This Out Help
I usually just keep the car in TOUR today I hit the button and played around wit the Traction Control I then went to TRACK and up came Wet Dry Well when I looked to change back to Tour the icon was different the TRACK ICON was Tr and the others were smaller "I think" I have been unable to get back to the original icons is this possible? Anybody ever seen this before?
Old Nov 2, 2022 | 06:45 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Pictures of what you mean may help?
Old Nov 2, 2022 | 09:34 PM
Maxpowers's Avatar
Maxpowers
A pic would help.
Old Nov 3, 2022 | 11:17 AM
x3
Old Nov 3, 2022 | 04:24 PM
KemahGT's Avatar
KemahGT
A better description in the Subject line may help. Lots of people on this forum don’t like click bait. (I almost didn’t click).
Sorry but I don’t have a solution to your problem.
Old Nov 3, 2022 | 04:45 PM
squirrelchew's Avatar
squirrelchew
sounds like you engaged PTM. I've yet to really figure out all the PTM stuff, the owner's manual is kinda fuzzy on it and what's online isn't much clearer. You should be able to exit PTM and go back to Tour by hitting the center button to re-enable TCS/DSC, then twist the outer ring to navigate back over to Tour from Track. You enter PTM by hitting the TCS button while in Track mode twice within a certain timeframe. If you don't have PTM I think you have a similar thing going on when in Sport or Track mode called "competition driving mode" or some such?
Not sure why anyone needs more than three modes, honestly:
1) keep me safe
2) let me have some fun
3) let me die
been noticing that a lot here. were I a mod, I'd be renaming the lot of these.
Old Nov 3, 2022 | 04:50 PM
CJ Willys's Avatar
CJ Willys
It’s possible that it will reset to Tour after shutting off. Or at least restore normal icons.
I’m assuming you have a non-Z51, only a push button to change modes??
Either way, drive a little distance in each mode before changing to another mode.
Old Nov 3, 2022 | 06:03 PM
Walter Raulerson
Z51 The letter size for the modes TOUR TRACK etc are different since I pushed the Traction button and the original size will not come back sorry about not being able to explain better
AND TO WHOMEVER I don't post to get clicks I might **** people off but I don't post for fun
Old Nov 3, 2022 | 06:05 PM
Walter Raulerson
Thanks so much for your support vetteman jack you are so helpful
Old Nov 3, 2022 | 06:36 PM
Hikerr's Avatar
Hikerr
It is really not a big deal disconnecting your negative battery terminal. Re-do your clock and you're good to go. Try that.
Old Nov 3, 2022 | 07:11 PM
squirrelchew
talk about the nuclear option, hah!
Old Nov 3, 2022 | 10:23 PM
KemahGT's Avatar
KemahGT
Not trying to be a smart ***, just telling you that some people don’t click on Subjects that either don’t interest them or they don’t click on something that’s vague. Nothing beats a colossal waste of time like clicking on something that says “Check this out help” and it’s a question on how to polish their tail pipes.
To Check This Out Help
