Failed Inspection-????????????
Old Dec 9, 2022 | 09:02 PM
B-STOCK's Avatar
B-STOCK
St. Jude Donor '14-'15, '17, '19
Default Failed Inspection-????????????
Just took my 2015 in for R. I. inspection. I am on good terms with the dealer I am still scratching my head. I had something to do with emission codes-eight off them total I think. They said if it was only one code they could pass it, but it was two codes. Then they noticed that they replaced the battery last month and the car would had to learn everything again and it would be OK. I we checked the mileage and the car had gone about 300 miles since the battery change, but they were done in two trips. Told me the computer worked on cycles and I had to do a lot of different types of driving. Short rides etc. Said to just drive it a lot and bring it back inn a couple of weeks. Ready to put the car in winter storage so this sounds nuts. What say. Legit ?
Old Dec 9, 2022 | 09:07 PM
Maxpowers's Avatar
Maxpowers
It is true the car needs a few cycles and has to be driven at variable speeds etc. Someone posted in detail what it is but I cant find it.
Old Dec 9, 2022 | 09:51 PM
ss2z06's Avatar
ss2z06
I believe you’re talking about monitors being set and not codes. Each state is different. In California all but evap need to be set. They do take driving and in a certain manner to set. Post up which ones aren’t set to get a better idea.
Old Dec 9, 2022 | 11:23 PM
B-STOCK's Avatar
B-STOCK
Thanks, I will ask the dealer which two are not set.
Old Dec 10, 2022 | 01:36 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Good luck!
Old Dec 10, 2022 | 08:39 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
I found this in my cheat sheets:
1. Start with a vehicle where the engine has cooled all the way down over night.
2. Fuel level between 1/4 & 3/4 full
3. Drive between 20 & 30 MPH for 22 minutes, allowing speed to vary.
4. Stop and idle for 40 seconds, gradually accelerate to 55 MPH.
5. Maintain 55 MPH for 4 minutes using steady throttle input.
6. Stop and idle for 30 seconds, then accelerate to 30 MPH.
7. Maintain 30 MPH for 12 minutes.
8. Repeat steps 5 & 6 four times
Now, get tested.
Elmer
Old Dec 10, 2022 | 08:42 AM
*89x2*'s Avatar
*89x2*
From: ...tearing up the highways, one state at a time™®©
This:
General Motors Drive Cycle For Smog Check
In order to get all your OBD2 monitors for your GM (Chevy, Buick, Cadillac, GMC, Pontiac, Oldsmobile) vehicle ready, please perform the following steps:
  • Start the vehicle from a cold start. The time to do this is if you have not driven the vehicle for a few hours and the engine coolant temperature is less than 50 degrees F.
  • Let the engine run on idle. Turn the A/C and rear defroster on. You are trying to apply electrical load to the system. (THIS IS A MUST)
  • Accelerate to 55 mph.
  • Hold a steady speed of 55 mph for 3 minutes
  • Let go of the accelerator and coast until the vehicle hits 20mph. Don’t apply brakes to slow down.
  • Accelerate again until 60 mph.
  • Hold steady for 5 minutes at 60mph for 5 minutes.
  • Decelerate (coast to slow down).
  • You may need to repeat steps 3-8 a few times if the battery was disconnected recently.
Old Dec 10, 2022 | 09:22 AM
brandonsmash's Avatar
brandonsmash
Yes, you'll want to take it on a few drives of varying lengths. I've done the GM smog check cycle and had that not work perfectly. If you just drive the car a bit it should reset the DTCs (so long as everything is actually functioning properly).
Old Dec 10, 2022 | 10:45 AM
edspec's Avatar
edspec
Finalist 2020 C7 of the Year -- Unmodified
Now, get tested.
Elmer
Thanks Elmer
Old Dec 10, 2022 | 03:51 PM
orca1946's Avatar
orca1946
I'm glad I don't need to smog checks here!!
Old Dec 10, 2022 | 04:11 PM
Mad*Max's Avatar
Mad*Max
Sometimes it can take a month to be "ready:
Old Dec 10, 2022 | 04:22 PM
dagartdan's Avatar
dagartdan
This happens to me as well two yrs ago. Changed the battery and lost my info. The inspection station slapped a rejection sticker on the windshield the day before heading to Carlisle. Drove to Carlisle and I was probably the only corvette there with a rejection sticker! Lol! This year, they slapped another rejection sticker on my 2016 z because my windshield washer motor didn’t work. Next yr I’m going to a different station!
Old Dec 10, 2022 | 11:28 PM
B-STOCK's Avatar
B-STOCK
I wonder of this is all BS. Supposed I traded my car to the dealer and he had someone ready to buy it. They would have to put a fresh inspection sticker on it. Would they give my car to a lot boy to drive it until it fixed itself? Doubt it. I think there is a way around this. When I go Monday and if it doesn't pass I want it fixed under warranty. In my simple mind if cannot pass inspection there is something wrong with the car that needs to be fixed. Had a friend, active and retired PD, and if he trusted you, give him your registration, $50 + the inspection fee and he got you a sticker that day. Too bad he died a few years ago. Ways to get around anything.
Old Dec 11, 2022 | 12:28 AM
Thanks for posting this information. I do not have an emissions inspection requirement here, but nice to know about this anyway.
Old Dec 15, 2022 | 02:08 PM
B-STOCK's Avatar
B-STOCK
Originally Posted by *89x2*
This:
I tried this and also a lot of stop and go city driving. Shut the car off and walked out of transmitter range to give it a recycle and it finally works. God, what a helpless feeling not having control of my smog devices.
Old Dec 15, 2022 | 04:14 PM
*89x2*'s Avatar
*89x2*
I am glad to have helped with the info I posted/shared. Just the facts on what really works, as they say...
Old Dec 16, 2022 | 02:17 PM
CraigStu's Avatar
CraigStu
It is all true. Admittedly I retired from being a Lexus tech 10 years ago but had gotten into some of these situations then. We tried several times to do a drive cycle that the ecu would accept. We finally gave up. As you can see the stated drive cycle is very detailed and your local traffic can easily prevent you from doing the next step. For instance.;
Think where you could do that. Hold a steady speed of 55 doesn't mean 50 or 60. I don't know exactly what the allowable range is but it isn't very wide. Then you get to let off the gas, no brakes, and coast to 20. And don't get rear ended. The thing is that if any step is done incorrectly you get to start over... from a cold start.
To Failed Inspection-????????????
Old Dec 16, 2022 | 07:47 PM
ss2z06's Avatar
ss2z06
Unfortunately there isn't really a trick like others have mentioned. Some manufacturers can force run the monitors with their scan tools. VW and their derivatives can. However Chevrolet can't. They can only force run evap if I remember correctly but that is the unimportant one. You can always make an appt with a state ref who can inspect the car and sign off.
Old Oct 11, 2023 | 02:57 PM
jmagilto's Avatar
jmagilto
Stop Disconnecting the battery when you don't drive it. get a battery tender instead.
Old Oct 11, 2023 | 03:40 PM
c5arlen's Avatar
c5arlen
This whole GM dance is almost humerus...... Unless one is involved.
