engine shut off while idling?
Old Dec 17, 2022 | 11:41 AM
Mad*Max's Avatar
Mad*Max
Default engine shut off while idling?
I have a 2019 Stingray and today I was idling and I believe after about 15 minutes the car shut off by itself. I was outside of the car with the fob in my pocket but I do this all the time and it has never shut off on me in almost four years.
I went to restart the car and would not (dead) until I put the fob in the slot and it started up right away.
Can all this just be due to a low fob battery?
Old Dec 17, 2022 | 11:54 AM
Mad*Max's Avatar
Mad*Max
I just found this in the manual so can't be the fob as it was less than half an hour:
"If the vehicle is left parked and
running with the Remote Keyless
Entry (RKE) transmitter outside the
vehicle, it will continue to run for up
to half an hour."
Old Dec 17, 2022 | 12:21 PM
jaiyenyen's Avatar
jaiyenyen
to half an hour."
Electronics are funny sometimes but having said that my C7 does shut off after idling for awhile and I don't think it takes half an hour.
Old Dec 17, 2022 | 12:33 PM
mdolandese's Avatar
mdolandese
Normal
Old Dec 17, 2022 | 12:38 PM
NortonCO's Avatar
NortonCO
Originally Posted by mdolandese
Normal
x2.
Old Dec 17, 2022 | 01:03 PM
orca1946's Avatar
orca1946
Have never seen/done this. I tried to remember leaving it idle for 1/2 hour ----- never.
Old Dec 17, 2022 | 01:18 PM
mdolandese's Avatar
mdolandese
Old Dec 17, 2022 | 02:03 PM
Mad*Max's Avatar
Mad*Max
Thanks for all the replies, just as a test I went to see if it will start up and indeed it did (without putting the fob in the slot) and behaved absolutely normal.
Old Dec 17, 2022 | 02:05 PM
Let It Ride's Avatar
Let It Ride
Mine shuts off anywhere from 20-30 minutes. Completely normal. The first time it did it I was alarmed, until I realized what was going on after reading up on it. 2019 also.
Old Dec 17, 2022 | 02:42 PM
Brunello's Avatar
Brunello
That is a good feature for these cars with remote start.
Funny story. I went on a cruise with a few other families and when we returned, my buddy’s car wouldn’t start. It was out of gas. He started losing his mind and yelling about “some dirtbag stole my gas.” It was NJ so he was even more convinced and accusatory. This went on for 15 minutes until a lot attendant finally told him he left the car on and it ran for probably 1-2 day. “Happens 10 times a week here” We still laugh about about his “stolen gas.” So if our Vettes shut off automatically, good. I’m that dumb too.
Old Dec 17, 2022 | 06:11 PM
Let It Ride
Actually nothing to do with remote start on our cars as it is just a safety feature I guess. I don't have remote start as my car is a M7.
Old Dec 17, 2022 | 08:23 PM
Mad*Max's Avatar
Mad*Max
me too
Old Dec 17, 2022 | 08:38 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
If your car has the Remote Start feature and you do a remote start, the car will shut down after 10 minutes.
You can extend the run time before shutdown, once, if you hit the lock and remote start while it's still running.
Old Dec 17, 2022 | 11:03 PM
Normal
Yep, the car will shut down after idling for a set period of time with the fob outside the car.
Old Dec 20, 2022 | 05:13 PM
Avanti's Avatar
Avanti
I don't care what the Manual says, it can be the FOB battery. I've found it takes very little voltage drop for it to "malfunction"... at least with mine. I always test replacement batteries to get the highest voltage possible. All the best.
Old Dec 20, 2022 | 06:03 PM
Gearhead Jim
St. Jude Donor '13
I don't see how a dead fob battery would cause the engine to shut down. Not start, yes. Shut down while running, no.
Engine shutdown from a dead fob battery would be dangerous- car dies in traffic, manual-only steering, limited power brakes, etc.
I've gotten out of our C7, taking the fob with me, many times with no problem. Gone far enough into the house that there would be no fob communication, but engine kept running. Drove it around the block a couple of times with the fob left at home, no problems. I had the fob battery die in my pocket a couple of times, but engine kept running.
Old Dec 20, 2022 | 10:22 PM
squirrelchew's Avatar
squirrelchew
Please, do tell how an idling, manual transmission C7 will shut itself down due to a malfunctioning keyfob.
To engine shut off while idling?
