Battery Charger
Old Dec 18, 2022 | 06:09 PM
Corvette Axl's Avatar
Corvette Axl
Default Battery Charger
I recently bought the trickle charger from Chevrolet. It runs very hot. Is this normal?
Old Dec 18, 2022 | 06:41 PM
mdolandese's Avatar
mdolandese
Try and do a search there should be some previous threads on this issue. Mine is usually really warm, but doesn’t get extremely hot. It may have something to do with how charged your battery is. Someone will chime in with some more in put.
Old Dec 18, 2022 | 07:40 PM
Kevin A Jones's Avatar
Kevin A Jones
Yes, they do get what I would consider hot as mentioned above when battery is at a low charge.
Old Dec 18, 2022 | 07:57 PM
Corvette Axl
My battery’s pretty much new. I keep it at my second house so worried about leaving it alone. Any thoughts? Should I return it?
Old Dec 18, 2022 | 09:13 PM
Ron_Attleboro_MA's Avatar
Ron_Attleboro_MA
I just checked mine that has been on the charger for days. It is cool\cold.
I do remember that once I used it to charge a dead battery and it did get hot.
Check your after a day, after the green light is ON.
Old Dec 18, 2022 | 09:32 PM
mdolandese's Avatar
mdolandese
Wow I’ve had my plugged in for 4 years whenever I’m not driving it and it’s never ever been cold. Warm is as coolest as mine as ever gotten.
Old Dec 18, 2022 | 10:46 PM
Harleymike's Avatar
Harleymike
Just checked mine. It is stone cold. But the battery says fully charged.
Old Dec 18, 2022 | 11:06 PM
aadadams's Avatar
aadadams
Generally speaking, chargers are not 100% efficient... The loss (or inefficiency) is typically given off as heat, and if the charger isn't actively charging the battery, it's reasonable that it would be cool!
Old Dec 18, 2022 | 11:17 PM
Avanti's Avatar
Avanti
These are "maintainers," not chargers. They will get hot if used on a very depleted battery; they are not intended for such use. If used as designed... to maintain a good, though charged battery, their sensation to the touch will vary from pretty warm (whatever that means--purely subjective) to cool.
Old Dec 19, 2022 | 03:19 AM
When the GM charger is actually charging the battery, it can get anywhere from warm to relatively hot. I would not classify it as getting really hot.
Old Dec 19, 2022 | 10:01 AM
69 L46 4 Speed's Avatar
69 L46 4 Speed
I have used the same type CTEK from GM on both my 13 GS and then on my 19 GS. Neither of them got to what I would consider hot. It is mounted on a concrete wall which would absorb most of the heat if it should ever get hot.
Old Dec 19, 2022 | 11:38 AM
orca1946's Avatar
orca1946
If it is working hard to bring it back up to full charge, then it will get warm/hot.
Old Dec 19, 2022 | 11:45 AM
JCBigblock's Avatar
JCBigblock
Cruising
Trying to decide whether to leave the charger plugged into the lighter socket in trunk all the time as I only drive the car in summer and not much than either, or put one of the disconnect green twist top units on it and not have to worry about battery drain. Don't really care about the loss of preset radio stations. Any other things I should know?
Old Dec 19, 2022 | 11:49 AM
bordo's Avatar
bordo
I use an Optimate 4 on my 2015 Stingray. It's been plugged in for about 1 1/2 days now. It is in the "voltage retention test" mode now and it is cool to the touch.
To Battery Charger
