Headers Only Sound
I put magnaflows and headers on my previous auto C5 convertible, that was supercharged.
That car had a deep sound but it was too much. It was downright unpleasant in the A4 vert.
My wife hated it.
I'm going off my experience with my Z51 with NPP. I have LT headers w/cats, cam/heads/intake/e85/tune. If I run in tour mode it is very close to stock and does not drone at all. In track mode with the NPP valves open it drones bad at low rpm on the highway.
I have a 66 chevy truck with a decent cam in the 350. I installed LT headers and had Flowmaster styled mufflers welded on. The old truck has a 350 turbo trans and 3.73 rear, but it's not as bad as the convertible was. I installed a lot of sound deadening in the truck and the exhaust exit is much further form the driver.
header -> catalytic converter(s) -> resonator(s) -> muffler(s)
getting headers on a c7 usually eliminates some or all of the catalytic converters, which will make your exhaust stinky, crackly, slightly louder, and throw check engine lights without an emissions-deleting tune.
cat-back exhausts USUALLY employ a resonator + muffler. a resonator looks like a small muffler. you remember cherry bombs at autozone back in the day? the big red tubes? those are technically resonators.
specific to the C7 --
this old thread shows a stock header collector, upstream cat, downstream cat, and xpipe setup. the mufflers go after all of that. the X-pipe is probably not resonated in this application, but serves as a resonator of sorts. a lot of the drone killing is happening with the catalytic converters, I reckon. not sure if the c7 mufflers have helmholtz/J-pipes in them, but if they do, that'll kill a lot of drone too (as those are very effective types of resonators).
I have the A&A SC kit with ARH LTHs and their catalytic converters.
What transmission do you have?
