Brake squeaking problem
Old Jan 22, 2023 | 04:57 PM
Nonylie@8390's Avatar
Nonylie@8390
1st Gear
Default Brake squeaking problem
Hello corvette aficionados,
Does anyone have squeaking brake problem, and how did you fix the problem?
Old Jan 22, 2023 | 06:57 PM
Bill Dearborn's Avatar
Bill Dearborn
It isn't a problem so really doesn't have a fix.
Bill
Old Jan 22, 2023 | 07:03 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Steel or CCB? You could try the Burnish process
Old Jan 22, 2023 | 07:53 PM
golden2husky's Avatar
golden2husky
Are you referring to brake squeal coming to a slow stop? That was a known issue on Z51 cars, at least for the 2014 model year. Mine had the problem. The dealer first changed the front pads which helped for a short while. They then replaced the pads again and fitted new rotors. Problem has not recurred.
To Brake squeaking problem
