quick jack
Old Jan 28, 2023 | 10:00 PM
Harleymike's Avatar
Harleymike
Default quick jack
question.
Will the extended version of the quick jack work on the c7 or is too long.
Old Jan 31, 2023 | 12:53 PM
NortonCO's Avatar
NortonCO
I have not yet tried to use mine on my C7Z, but the tape measure says it's too long. Since my other vehicles require the extended version, I plan to use it sideways with the C7...
Again, the tape measure says it SHOULD work that way.
Old Jan 31, 2023 | 01:25 PM
Harleymike's Avatar
Harleymike
Hmm that might work, then I can buy the extended ones and use them on the hellcat. I will double check the math. thanks
Old Feb 1, 2023 | 06:47 AM
mdformula350's Avatar
mdformula350
i got the standard size one 5k one, they make an extension setup to place on the regular size one to work for longer items
https://www.quickjack.com/accessories/frame-extensions/
i know it probably adds to the height of it but thats what I would try verses going sideway lifting.
Old Feb 1, 2023 | 10:14 PM
NortonCO's Avatar
NortonCO
Good tip on the extension setup, for those who haven't purchased yet and don't mind the extra expense and height.
Why is that "what [you] would try verses going sideway lifting," despite the manufacturer's recommendation that they can safely be used both ways?
Old Feb 2, 2023 | 11:51 AM
AnotherNorskie's Avatar
AnotherNorskie
Why is that's "what [you] would try verses going sideway lifting," despite the manufacturer's recommendation that they can safely be used both ways?
I'd guess sideways may block access to things like the torque tube / tunnel.
Old Feb 2, 2023 | 11:54 AM
NortonCO's Avatar
NortonCO
Agreed, but that shouldn't pose any problem for most wheel/tire/brake work or detailing. Not sure I'd want to undertake torque tube/tunnel work only a foot or two off the ground.
To quick jack
