Take the screws loose for the forward section of the front fender liner, then you can reach in and release the clips on the side marker. There are three clips if I recall correctly. Once the clips are undone, pull the light out and disconnect the electrical connection.
Are you referring to the lights at the rear of each fender?
Elmer
Aaack! I meant the front. Those are in front of the front wheel and to the rear of the rear wheels. They are called side markers. Post #4 is the answer.
You could also look up Oracle online and watch video on installing those, it will show a video on how to access that location. Go to this page and look for the C7 vid, look at vid pics not captions.. they are wrong underneath videos.
I watched a few videos on youtube to get the gist of the install.
this one was fairly clear on showing the bolts and tools, plus the front wheel placement for ease of access.
