Tires pressure reading 38-41
Interesting thread. My 2016 Stingray's door jam calls for 30 PSI. It has 19" front tires, and 20" rear tires. An increase of 5 pounds is not uncommon once tires warm up from a few miles of driving.
My 2017 stingray with 18 front and 19 rear shows 35 PSI in all four tires on the inner door jam. I am going to get me a good air pressure gage and set them at 35 PSI and that will be the end of the tire pressure question for me.
Received 2,240 Likes
People have to live with the choices they make in life. Be prepared to replace your tires because of uneven wear in the center of all of your tires.
All the tires are the same on the Base Stingray(non Z-51). 18's and 19's. No matter what year. For some reason on the 2017's they have 35. All other years I think have 32lbs. I run mine at 32. 35 was for gas mileage someone said, why the 2017 year, who knows. Also if 35LBS is too much. You may have uneven wear up the center. Don't know if 3lbs really makes that much difference but to me 35lbs rides too hard.
It was 35 psi for 2016's also with the standard 18/19 wheels. All others C6, C7 & C8 have 30 psi on the door jamb. So it's a 5 psi difference. That makes a difference.
Thanks Walt for the clarification. I think I will run mine at 30lbs. It's funny, when the my 2017 gets down to 32LBS I get a low pressure warning because of the 35lbs. I wonder who thought 35lbs for two model years (16 $ 17) was a good idea?
Moderator/Tech Contributor
Location: Jacksonville Florida BWO Dayton, Cincinnati, Bloomsbury NJ, Cincinnati
Received 3,831 Likes
2015 C7 of the Year Finalist
Elmer
The following 2 users liked this post by eboggs_jkvl:
Gearhead Jim (02-23-2023),
mbaessler (02-22-2023)
WOWSER 🙄. You folks must lead a very worrisome life. Reminds me of another OCD post couple years ago—BUT WHAT ABOUT WHEN *****? He said he/she would stop after driving “awhile” and let air out of the tires to keep them at 30psi after they had risen a few degrees 👀
#35
I take pressure in the am when the car is left outside overnight and be done with it.
#36
Standard Day Pressure
I think the cold temperature is a non heated tire. If the ambient temperature is 80, you set the air to 30 PSI. If the ambient temperature is 40, you set the tire pressure to 30 PSI. A cold tire is a tire that is not warmed up because of driving the car and raising the temperature.
Don't go into a black hole of well if it's ###°, you should set the PSI to YYY° because of the ambient temperature. Let the tires cool overnight, set the PSI to 30 and drive the darn car.
STOP with the "well, what if the tire temperature is 147.9 degrees? What do I set the PSI to?" Set it to 30 PSI if the tire hasn't been driven overnight and have road heat in it. Geeesh...
Elmer
Elmer
Engineers use a basic referenced starting point for cold tire pressure called “standard day pressure.” Keep in mind that we are merely checking differential pressure when we check our tires. A standard day is 15 degrees Celsius (or 59 degrees F), 60 percent relative humidity at sea level with standard atmospheric pressure of 29.92 inches of mercury (or 14.7 lbs per square inch). If you can approximate these conditions or mathematically adjust for these 4 variables, you will achieve a more accurate tire pressure.
Ultimately, it is a bit like measuring with a micrometer, marking with chalk, and cutting with an axe.
madrob2020 (02-22-2023)
#38
Um, if the tire pressure starts out at 30PSI, it will increase for 4 - 6 psi as normal as the tire temperature increases. Doesn't really matter where you live. It starts at 30PSI and goes up. It won't blow up the tires and have them explode.
Elmer
#39
I've had TPMS warning for low pressure in the am. I usually prefer to over inflate the night before, leave it outside and adjust it in the morning. Between over inflation or under, I'd prefer over.
