C7 secret?
Old Feb 19, 2023 | 04:02 PM
vetten76's Avatar
vetten76
Default C7 secret?
I replaced my battery in my 19. All was good except it wasn’t good. The door wouldn’t open. Popped the door open with the cable. I closed the door and cussed for a little bit. I started yanking on the door opener. About every 5th yank, the window dropped about 3 inches. I kept doing that until it was all the way down. The fob was not in the car. Door still didn’t work, but the window was down. My problem was that the positive cable on the side slipped under the rear plastic cover. I didn’t see it. Oops. Put that back on and all was good. That window thing was interesting. Has anyone else seen that?
Old Feb 19, 2023 | 09:37 PM
Buddhaman's Avatar
Buddhaman
Probably due to not having the windows indexed properly. You’re supposed to roll the windows all the way down and back up to set them after changing/unhooking the battery.
Old Feb 19, 2023 | 09:46 PM
Avanti's Avatar
Avanti
Yes, the Manual says to index the windows after the battery is disconnected.
Old Feb 19, 2023 | 09:55 PM
Glad you figured it out.
To C7 secret?
