Starting issue
Old Feb 22, 2023 | 12:31 PM
Buckner21's Avatar
Buckner21
Default Starting issue
My 2016 stingray will start strong most days but some days it's real week and even when I drive for a little bit, stop and get gas and some times it won't start back. Put a new alternator on it and it was fine for a while and then started doing it again. Checked new alternator and it shows good, checked battery and it shows good🤷 . What should I check next.
Old Feb 22, 2023 | 12:41 PM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
How old is your battery.?
Old Feb 22, 2023 | 12:47 PM
Buckner21's Avatar
Buckner21
4yrs old,
Old Feb 22, 2023 | 12:57 PM
CorvetteMike2024
Corvette Enthusiast
Is it AC Delco? Passing a battery test at Auto Zone doesn't mean its necessarily good.
Old Feb 22, 2023 | 01:21 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
I would get a new battery.
Old Feb 22, 2023 | 03:30 PM
jimmbbo's Avatar
jimmbbo
At four years, you're in the "Battery Roulette Zone", depending on where you live... Average battery life is 3 - 4 years in most climates.
Old Feb 23, 2023 | 07:17 AM
lassie's Avatar
lassie
Battery, Starter motor, Fuse box maybe.
Old Feb 23, 2023 | 08:32 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Battery.
Elmer
Old Feb 23, 2023 | 08:49 AM
Zjoe6's Avatar
Zjoe6
Moderator
Old Feb 23, 2023 | 09:29 AM
joemessman's Avatar
joemessman
That's why I replace mine every three years regardless. For the price of a new battery, that is pretty cheap insurance.
Old Feb 23, 2023 | 10:13 AM
mharris1984's Avatar
mharris1984
Battery. The LT engine is like the LS. I would go through new batteries every 2 years with the PHX heat and high compression starts of the LS. The LT is the same way and hard on turn over, so weakens batteries out every few years. If your battery is older then 2 or 3 years, replace it, even if it tests good.
Old Feb 23, 2023 | 10:23 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
When, I picked up my used 2016 from CarMax, they put a new off-brand battery in it. I started having problems after a year. I replaced it with an AC Delco 42 month Battery and no more issues.
Old Feb 23, 2023 | 10:30 AM
Factoid's Avatar
Factoid
The battery is cheap insurance and worth adding to your maintenance schedule particularly if you live in a hot climate like mine here in south Texas.
Old Feb 23, 2023 | 11:42 PM
I would be looking at the battery since it is 4 years old. May not be it, but an easy thing to rule out.
Old Feb 24, 2023 | 05:58 AM
mdformula350's Avatar
mdformula350
if its not cranking over strong then i would agree its leading towards the battery.
if its cranking over strong but just not starting especially after warmed up sounds like possible other issues possible spark/fuel related..
either way with an older battery and issues around cranking certainly pointing to a battery related issue.
could always pull it get it tested to get an idea. but its on the older end of its life most likely.
To Starting issue
