Custom Garmin Mount for C7
Old Mar 24, 2023 | 05:47 PM
rigelkentaurus's Avatar
rigelkentaurus
Default Custom Garmin Mount for C7
I designed a Custom Garmin Mount for my C7 and 3D printed it using PETG transparent filament. It is temporarily attached to the passenger console hand hold with common velcro straps and thereby is easily strapped in place when desired. A Garmin with a "ball mount" then just snaps on the ball post (just like the regular ball post for the Garmin bean bag mount) and the power plug is very conveniently located on the console. I have used it with a 4 inch Garmin and with a 6 inch Garmin. There is no conflict with either the cup holder or the manual gear lever. If anyone has a 3D printer and wants to print it, just email me and I'll send you the STL file.
Old Mar 24, 2023 | 09:40 PM
Nice job on the mount.
Old Mar 25, 2023 | 02:20 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Old Mar 25, 2023 | 01:29 PM
Jeff T.'s Avatar
Jeff T.
St. Jude Donor '13 thru '26
I didn't realize folks still used GPS units...
If it makes you happy!!
Old Mar 26, 2023 | 05:40 PM
orca1946's Avatar
orca1946
Very inventive
Old Oct 7, 2023 | 05:07 PM
Emerald Eagle's Avatar
Emerald Eagle
Hello,
Several months ago you sent me the file to create your mount for my car.
A friend that is in engineering school has access to a printer and got one made. I just got to use it on a 2000 mile trip and it was way handier than on the dash! Our car has the onboard gps but I like the Garmin better. I use both since I can look at the weather enroute when the onboard system is programed.
I was able to take better advantage of the information on the screen since I could easily tap the access points. We have the M7 and it was no issue running the lever. Even though we had the smoked top in for this trip the reflectance from the interior was not an issue as it is on the dash. When installing the ball in the socket I found that the ball on the printed bracket was .025" smaller on the dia that the ball on the original bracket. I used a bit of epoxy to build it up and all was good.
Thank you for the innovative design and your willingness to share it.
The C-7 has 85k on the odo so it does get used and having the gps at my fingertips works great.
All best regards,
Ned
Old Oct 8, 2023 | 08:18 AM
76-Vetteman's Avatar
76-Vetteman
Great job on the mount.
Do you have a photo available with the Garmin unit mounted? Very interested to see the complete setup installed. Tks
Old Oct 8, 2023 | 04:21 PM
rigelkentaurus
Here are two pictures, one with a 4 inch Garmin and one with a 6 inch Garmin. I have used both on long road trips with this custom mount.
Old Oct 9, 2023 | 11:55 AM
76-Vetteman
Thanks for the updated photo. Looks great...
To Custom Garmin Mount for C7
