Need help
Old Mar 27, 2023 | 06:55 AM
JordanC's Avatar
JordanC
7th Gear
Default Need help
Has anyone upgraded from the stock in tank fuel pump on a c7 stingray? If so what brand is the best. I’m tryna to run e85 aswell. The stock system seems like it can’t keep up running full e. And will I need to get different injectors? Thanks
Old Mar 27, 2023 | 02:52 PM
Lux's Avatar
Lux
Just a tip. Be more descriptive in your titles and you'll get quicker help answering your questions. Someone who is knowledgeable might not bother to click "need help".
Old Mar 27, 2023 | 05:02 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
Plus post in C7 Tech/Performance.
Old Mar 27, 2023 | 07:50 PM
ZO6LIFE's Avatar
ZO6LIFE
The DSX aux pump should do the trick. I would get whatever injectors your tuner likes to work with. You will need a tune. DSX also has the E85 kit. You also may want to invest in a E content gauge so you can tell how the local stations are with their % of E mixture. Occasionally run a tank of 93 through it as well. It helps clean the gunk out.
To Need help
