Range AFM/DFM Disabler
Old Apr 3, 2023 | 01:48 PM
63WKU's Avatar
63WKU
Default Range AFM/DFM Disabler
Which Range AFM/DFM Disabler is most recommended? RA003R?
Old Apr 3, 2023 | 01:52 PM
TxLefty's Avatar
TxLefty
RA003 is what you need. The B, R or G at the end is just the color of the LEDs on the device. I got blue. It's working fine.
Old Apr 3, 2023 | 01:55 PM
63WKU's Avatar
63WKU
Much thanks for the advice. I failed to include that I just purchased a 2015 Z51 that likes to switch down to V4.
Old Apr 3, 2023 | 02:04 PM
TxLefty's Avatar
TxLefty
Congratulations on the purchase. I'm sure that you will enjoy it. I recommend the Range product. I've had it in place for a couple of years and it works as advertised. If your state requires an inspection there is a reasonable chance that you will need to remove the device and put the car through a few drive cycles to ready it for inspection.
You might also check to see if the vehicle has had the "triple flush". This process is to flush the old formulation transmission fluid and replace it with the new (roughly March 2019) ATF. It's not inexpensive, and there can be significant variation in price between dealerships. As I understand it the new fluid does not absorb water thus doing a better job of preserving shift quality and transmission parts, particularly the torque converter.
Old Apr 3, 2023 | 02:15 PM
Bills17n72's Avatar
Bills17n72
yes you will like it!!
Old Apr 3, 2023 | 04:09 PM
63WKU's Avatar
63WKU
I checked with the local Chevy dealer today regarding the transmission flush. Nearly $800. I don't know if that is high, low or about right.
Also trying to locate a set of mint OEM chrome wheels. Mine has the black wheels which I dislike. Looked at a set today here in Louisville. They have the "Corvette" logo on the outside of the rim, but I couldn't find a GM part number on the inside. Not sure if they are OEM, although I would guess GM would not allow any wheel manufacturer to use the "Corvette" logo?
Already love this Z51. It will go. This is my 66th Vette. Mostly owned mid-years. I also have a 2002 with 11,400 miles that I will be selling.
Old Apr 3, 2023 | 05:11 PM
maj75's Avatar
maj75
If I read the owners manual correctly the variable displacement only occurs in ECO mode and does not work in Sport or Track. If that is correct, why buy one of these devices when you can turn the feature off with your driving mode?
Old Apr 3, 2023 | 05:57 PM
63WKU's Avatar
63WKU
I drove mine in Sport mode yesterday and it still reverted to V4. It only stopped when I put it in manual and used the paddles.
Old Apr 3, 2023 | 06:37 PM
maj75's Avatar
maj75
Sorry, I think I’m right for manual transmission cars, not automatics.
Old Apr 3, 2023 | 06:46 PM
63WKU's Avatar
63WKU
Thanks for trying to help me.
Old Apr 3, 2023 | 10:02 PM
The Range AFM Eliminator works great - I have had one on my car for four years and it has not seen V4 in that period of time. Mine is an A6.
Old Apr 3, 2023 | 10:21 PM
63WKU's Avatar
63WKU
That's great news. I ordered one today.
Old Apr 3, 2023 | 10:50 PM
Keith Richards's Avatar
Keith Richards
Had one in my 2019 GS since a week from new, I drive Vettes to run on all 8.
Old Apr 3, 2023 | 11:07 PM
aklim's Avatar
aklim
That sounds about right ASSUMING they have the machine to do it. THIS is the process, I believe. See if they have that machine and 24 quarts of fluid. At $18 a quart it comes to $432 of fluid plus tax. After which, we have to consider labor to flush it several times, etc.
Old Apr 4, 2023 | 08:40 AM
63WKU's Avatar
63WKU
Yes, I looked at the service bulletin yesterday. It shows specific equipment needed to perform the flushes. Thanks for your advice.
Old Apr 4, 2023 | 10:10 AM
joemessman's Avatar
joemessman
You can buy the fluid at walmart for about $10 a quart. Bring it to the dealer when you bring the car in if you decide to flush. Rockauto hast the filter, gasket, etc. for less than half of what the dealer will charge you.
Old Apr 4, 2023 | 10:18 AM
aklim's Avatar
aklim
I'm seeing $69 plus tax for a 6 pack. Unless you feel lucky enough to trust in the other sellers. They might not want to work with parts you bring in. I don't blame them.
Good luck with Rock Auto. I can't afford their prices since it comes with a good potential for aggravation.
To Range AFM/DFM Disabler
Old Apr 4, 2023 | 10:33 AM
TxLefty's Avatar
TxLefty
Most dealerships won't. They want to make the money from selling the parts and they typically warrant their work and they would probably be uneasy using someone else's parts for that reason.
Old Apr 4, 2023 | 10:36 AM
aklim's Avatar
aklim
They would be good if it was something they don't carry but usually not for you to use a cheaper price part and lose the profit from the parts department
Old Apr 4, 2023 | 10:50 AM
Steve_R's Avatar
Steve_R
St. Jude Donor '12 thru '17
I bought my 2014 new. It has never been in V4 mode because I always use the paddle shifters. More engaged driving it that way and no need for an aftermarket device.
