Steering abnormality?
Old Apr 5, 2023 | 10:25 PM
CaptJimDavis's Avatar
CaptJimDavis
Default Steering abnormality?
In a parking lot environment while slow maneuvering when steering fully turned to either left or right I feel a wobble and it feels like a front tire going to fall of... or as if the ground is not even and flat.
But when straight away or halfway turn applied to the steering everything feels rock solid and perfectly aligned.
Is that an abnormality or ????
Old Apr 5, 2023 | 10:36 PM
fritz1990's Avatar
fritz1990
Normal. Called the Ackerman Effect. Can find all you need to know in search.
Regards, Jeff
Old Apr 5, 2023 | 11:17 PM
jimmbbo's Avatar
jimmbbo
Also, if it is annoying enough when you're ready for new tires, the effect it is much less pronounced on the AS4 all season tires at the probable cost of some slight marginal performance decrease
Old Apr 5, 2023 | 11:32 PM
CaptJimDavis
Regards, Jeff
Thank you, I appreciate the info... I'll read about it...
Old Apr 5, 2023 | 11:50 PM
Regards, Jeff
Yep - normal and if you do a search, you should find a number of threads concerning this issue.
Old Apr 5, 2023 | 11:55 PM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
More than slight I am afraid if you drive hard
Old Apr 6, 2023 | 08:55 AM
bassmobile's Avatar
bassmobile
It's actually mentioned in the owners manual. If this is your first Vette, I highly suggest you read through it.
Old Apr 6, 2023 | 09:39 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
From the Owner's Manual:
Tire Chatter/Hop
When driving at slow speeds and in
very tight turns, the vehicle may
have tire chatter/hop. This is normal
and the vehicle does not require
service.
Old Apr 6, 2023 | 10:28 AM
Elk's Avatar
Elk
Actually, there is no such thing as "Ackerman effect." (Unfortunately there is a dealer website article that erroneously states this, confusing people.)
Ackerman patented a steering geometry which alleviates the hopping/chattering. Ackerman steering however compromises performance.
The C7 does not have Ackerman steering geometry and thus the tires hop.
Elk is invisible Report Post
Old Apr 6, 2023 | 11:14 AM
miami08VETTE's Avatar
miami08VETTE
The Manual is your best friend....
Old Apr 6, 2023 | 04:40 PM
ICONIC7's Avatar
ICONIC7
2025 C7 of the Year Finalist - Modified
2023 C7 of the Year Finalist - Modified
As stated above, all season tires will eliminate this effect.
Old Apr 6, 2023 | 06:55 PM
CaptJimDavis
C'mon now Miami... Manual is for the lonely people and as we all know " Real men don't read manuals!!!"
Seriously I should be reading the manual but after two pages my eyes begin to close and all I want a long nap! So it's more fun to ask friends and learn in person...
Old Apr 6, 2023 | 07:13 PM
CaptJimDavis
So, this is an interesting point...
Old Apr 6, 2023 | 07:49 PM
Elk's Avatar
Elk
It is a common misnomer to refer to the hopping of the tires as the "Ackerman effect" when there is only Ackerman steering. All Mr. Ackerman did was to patent a steering geometry which solves the problem. He was not the first to identify the problem, he did not name it, or have anything to do with the underlying physics of the issue. The symptom is a matter of physics.
To call the wheel hopping the Ackerman effect is to name the solution after the problem. It is equivalent to calling a sour stomach the "Tums Effect" because chewing a couple of Tums solves the problem.
Of course, none of this has any impact on tire judder or its solution.
To Steering abnormality?
