What is this???
Old Apr 22, 2023 | 03:06 PM
Rbohno's Avatar
Rbohno
Default What is this???
This was in the back cubby with rotor cooling rings and the gas filler neck
This looks like some kind of antenna
Old Apr 22, 2023 | 03:08 PM
Zjoe6's Avatar
Zjoe6
Is it solder?
Old Apr 22, 2023 | 03:12 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Originally Posted by Zjoe6
Is it solder?
My guess too.
Old Apr 22, 2023 | 03:37 PM
orwollma's Avatar
orwollma
I believe it's the wire used to attach the Z51 rotor cooling rings if you want to drive your Z51 on the track. My first C7 Z51 came with the rings and the wire spool and some mounting instructions.
Old Apr 22, 2023 | 04:13 PM
Maxpowers's Avatar
Maxpowers
Mine came with the same wires for the cooling rings.
Old Apr 22, 2023 | 04:26 PM
Maxpowers's Avatar
Maxpowers
Here is a pic in the original packaging.
Old Apr 22, 2023 | 05:53 PM
Fed Up's Avatar
Fed Up
"My Dad's a TV Repairman"
It's safety wire. It's used to retain the rings through the holes to the hub. A normal set of pliers, grasping the two ends of the looped wire can be used to twist the ends together, preferably at a 45 degree angle. If you're high speed and low drag, you can get a set of safety wire pliers or speed pliers.
Old Apr 22, 2023 | 09:01 PM
Interesting - first time I have seen that since I do not have a Z51 car.
Old Apr 23, 2023 | 08:18 AM
Tinkertech's Avatar
Tinkertech
looks like a roll of solder wick to me.
Used to suck up solder from a joint.
Old Apr 23, 2023 | 08:47 AM
Catfish4818's Avatar
Catfish4818
Haha! I had the same question back here - https://www.corvetteforum.com/forums...age-compt.html
Old Apr 23, 2023 | 09:54 AM
eboggs_jkvl
Moderator emeritus
My lump of "solder" is still in the plastic bac with the discs in the garage. Still virgin! I will sell for a ridiculous price that will embarass anyone that bites!
Forgot all about that stuff that came with the car.
Elmer
Old Apr 23, 2023 | 11:12 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
Never seen that either...
Old Apr 23, 2023 | 11:22 AM
stevettec7's Avatar
stevettec7
I actually used my cooling rings and safety wire the first time I tracked my car. Of course the stock Z51 rotors with the rings still didn’t dissipate the heat very well. I wound up swapping them out for better aftermarket rotors.
Old Apr 23, 2023 | 12:57 PM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
Boy, that brought back some ancient memories.
Before Loctite in the early 1970's, I used to Campaign a Honda 350 and then a Yamaha RD 350 in Open Production Road Racing.
Just about every bolt and nut was Safety Wired and that was a major pain to do. There was a special tool for the wire, after you drilled the hole through the nut and bolt.
Old Apr 23, 2023 | 08:46 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Our 2017 Z51 came with the newer one-piece rotors, and so didn't need/couldn't use the cooling rings, wire, etc.
But when I looked in the cubby, all that stuff was there; just waiting for me to throw it away.
To What is this???
