2014 Shifter cable?
Old Apr 23, 2023 | 09:12 PM
Slck14's Avatar
Slck14
Default 2014 Shifter cable?
Hello all.....Well I did it to myself...While installing my AWE Track axle back exhaust I apparently put a kink in my shifter cable and now it won't shift through gears. On that I have ordered a new shifter cable and was wondering if anyone has ever changed it and if so any special things to look for? Thanks!
Old Apr 24, 2023 | 01:04 PM
fritz1990's Avatar
fritz1990
I changed mine on my C6 when I did fuel pump. Removed tunnel cover plate and panel around shifter ****. Had to make sure cable was adjusted properly. Not a big deal on the C6 and I assume the C7 isn’t much different??
Not much help but I’ll get you a bump to the top!
Regards, Jeff
Old Apr 24, 2023 | 03:40 PM
Slck14's Avatar
Slck14
Thanks Jeff!
Old Apr 30, 2023 | 07:54 PM
Slck14's Avatar
Slck14
Well going to tackle this tomorrow...just checking one last time to see if anyone has done this before and what I need to pay attention too? Thanks
Old May 1, 2023 | 01:31 AM
In to see your report on how difficult the job was. If you can, pics would be great.
Old May 1, 2023 | 07:52 PM
Slck14's Avatar
Slck14
Well got it changed today. Had to remove XPipe, heat shield blanket and drivers side exhaust pipe. Wasn’t an extremely hard job but did present some challenges. Would have been a lot easier if I had smaller hands…lol
Old May 1, 2023 | 08:20 PM
fritz1990's Avatar
fritz1990
Glad you got it done and thank you for reporting back!
I guess when I did my C6 all that stuff was already off when I did fuel pump.
Regards, Jeff
To 2014 Shifter cable?
