c7 front splitter
Old May 4, 2023 | 01:37 PM
f1reb1rd's Avatar
f1reb1rd
Default c7 front splitter
This item NUBEHONE Front Bumper Lower Lip Splitter Carbon Fiber Look Fit for 2015-2019 Chevy Corvette C7 Z06 & Grand Sport Replaces OEM #22922352 ABS Plastic - Hydro-Dipped Carbon Fiber. mfg said this does not fit if you have a stage 3 with winglets
Manufacturer Part Number ‎NH-C440V01
Can you add winglets. Can you add winglets.
Answer:
no
By raymond elliott on January 24, 2023
anyone know why not it appears to fit
Will this work with winglets on a stage 3 as replacement for only the center or is this strictly a stage 1 and can’t be used with existing state 3 win Will this work with winglets on a stage 3 as replacement for only the center or is this strictly a stage 1 and can’t be used with existing state 3 win
Answer:
no on either. wrong size for c-7
"><img src=" /> ">
raymond elliott"><span style=raymond elliott" /> raymond elliott">raymond elliott
· January 24, 2023
Old May 4, 2023 | 01:41 PM
SladeX's Avatar
SladeX
It's most likely because they didn't drill holes in the side for them. EOS does this too with their splitters, the stage 2 kit they sell are undrilled at the sides and require you either drill it yourself or use double sided tape.
Old May 5, 2023 | 10:37 AM
f1reb1rd's Avatar
f1reb1rd
i thought of the same thing but it was a guess. thanks for that feedback
To c7 front splitter
