Battery Question
Old May 12, 2023 | 07:18 AM
Captainnick's Avatar
Captainnick
2nd Gear
Default Battery Question
What is the battery life 2019 C7 Corvette
Old May 12, 2023 | 07:41 AM
Travlee's Avatar
Travlee
in my 2015 it lasted almost 7 years. texas heat killed it last summer
Old May 12, 2023 | 07:48 AM
dvilin's Avatar
dvilin
Bought my 2019 Vette new i late 2018 battery is still good. However whenever it is not being driven it is on the battery tender.
Old May 12, 2023 | 09:36 AM
Power Hawk's Avatar
Power Hawk
I keep mine on a battery tender. I had the battery on my 2016 replaced earlier this year. Even though it still tested OK, I did not want to take any chances as we were going on an overnight trip.
Old May 12, 2023 | 10:22 AM
Maxpowers's Avatar
Maxpowers
I replaced mine at 4 years proactively. These batteries seem to just die with no signs.
Old May 12, 2023 | 10:24 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
I load tested mine in my 2017 Z... still reads same as new.... always tended and not in freezing temps.. a roll of the dice I think though
Old May 12, 2023 | 10:26 AM
cdnrx1's Avatar
cdnrx1
My 2019 GS was purchased new in April of 2018. It is in unheated storage from November 1st until April 1st and spends all winter on the battery maintainer. Same for periods of more that a week during driving season. The battery load tested "good" recently and shows no signs of deterioration. I know that 5 to 6 years is the average life expectancy of the OEM battery so I'll be keeping a close eye on it from here on in but, so far so good.
Old May 12, 2023 | 11:05 AM
I would say 5-7 years is the expected battery life. I replaced the original battery in my 2014 after 5 years - nothing was wrong with it but just did a proactive replacement to prevent any problems. I do keep my car hooked up to a battery tender when not being driven.
Old May 12, 2023 | 01:59 PM
Vette Ski's Avatar
Vette Ski
I do keep my 2019 GS , made in 4/18 on a tender when not being used. Tenderizing it is a must.
Rich
Old May 12, 2023 | 02:53 PM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
Since we drive to remote areas with no cell coverage, I used to replace our C5/C6 battery every 3 years (~35k miles). With the C7 battery that isn't exposed to the hot engine compartment, I'm using a 4 year cycle.
Old May 12, 2023 | 03:59 PM
Black Rose-MD's Avatar
Black Rose-MD
2014 Z51....Sold with the original battery in 2021 (no issues) - 7 yrs old, kept on tender
2017 GS... New to me when purchased December 2022...no issues with battery but changed it anyway a month ago... - 6 yrs old but purchased new one as I knew one would be needed soon anyway and why push my luck not knowing if the previous owner used a tender or not.
A 2019 of course would be 4 yrs old...if no issues and it tested fine, I'd probably go 5-6 yrs but test it every year as you would be rolling the dice....
Old May 12, 2023 | 04:06 PM
jimmbbo's Avatar
jimmbbo
Depends on where the car lives, whether it's on a maintainer when sitting, and/or how often it's driven. High ambient temps and sitting are battery killers.
Old May 14, 2023 | 11:22 PM
jlbruggeman's Avatar
jlbruggeman
Keep it on a Tender on anything over a week, replace every 5 years, end of story. You will be safe.
Old May 15, 2023 | 10:18 AM
Gearhead Jim
St. Jude Donor '13
Perhaps, depending on where he lives. No location info in his profile.
The map in post #12 is a good start.
Old May 15, 2023 | 10:32 AM
sjw91's Avatar
sjw91
I live in a red zone and replaced my battery at 5 years, just for peace of mind.
Really not hard to replace, but be careful with that tiny black wire. It stayed attached when I did the replacement, but I must have pulled a little too hard on it. After a week of driving, it had worked itself out of the connector, and I started getting the Low Battery warnings.
Old May 15, 2023 | 12:26 PM
Bayshore Vette's Avatar
Bayshore Vette
@C7GSM7VERT
I've had my 2019 GS since 4/21. Still has OEM battery. No tender and don't think I need one here in the S.F. Bay Area. Still running strong, driven regularly. But I am a member of AAA with 100 miles range. Four (five?) years so far and throwing the dice...
Old May 15, 2023 | 12:32 PM
Mad*Max's Avatar
Mad*Max
My 2019 was built March 2019, I will keep the original battery till March 2024 and proactively change it at that time.
Old May 15, 2023 | 12:37 PM
squirrelchew's Avatar
squirrelchew
My 2018's battery died maybe a month ago with little warning at around 18k miles. Bought around 15k in October, so there's no telling what it went through.
It's an FLA battery from the factory. Expect 4-7 years out of them. An AGM under normal usage will see 7-10 years, and with proper care taken they can last 10-20 years -- my first AGM from the 90s lasted somewhere around 14 years after being repeatedly flatlined.
It might be worth noting that I never use a battery tender. YMMV.
Old May 15, 2023 | 10:23 PM
I replaced mine when it was between 5-6 years old. Noting wrong with it, but I just felt I was on borrowed time and did not want to have a failue at a most inopportune time.
To Battery Question
