No gauge lighting
Old May 13, 2023 | 09:03 AM
Torch Red #32015's Avatar
Torch Red #32015
1st Gear
Default No gauge lighting
After sitting for 6 weeks. The 2015 Z06 did not start. After charging the battery, the Z06 did start . As I was leaving the garage , I noticed that none of the dask gages were showing except the radio and the ac dials along with the ac controls. What do I need to do to gring back the gauges.
Old May 13, 2023 | 09:49 AM
CorvetteMike2024's Avatar
CorvetteMike2024
Corvette Enthusiast
Make sure the little black wire on the negative terminal is hooked up and making good contact. Make sure all other connections are good and tight.
Old May 13, 2023 | 10:41 AM
I agree - if not hooked up, that little black wire can cause problems.
Old May 13, 2023 | 11:08 AM
Grand Slam's Avatar
Grand Slam
If you haven't already done so, start your car again and see if they return. Often restarting resolves electrical problems.
Old May 13, 2023 | 11:43 AM
madrob2020's Avatar
madrob2020
Is battery original? Dying batteries cause electrical problems since you said battery wouldn’t start car.🍻
Old May 14, 2023 | 05:20 PM
mdolandese's Avatar
mdolandese
Is it the original battery? Sounds like it's time for a new one
Old May 14, 2023 | 10:26 PM
Avanti's Avatar
Avanti
And, make d**ned sure your new battery is good. Don't ask why I suggest this.
To No gauge lighting
