spark plug replacement
Old May 16, 2023 | 04:02 PM
Jaykoh-Z51's Avatar
Jaykoh-Z51
Default spark plug replacement
Got a few projects coming up on my C7, spark plugs is on the list. What have you guys installed? OEM? something better? I'll also upgrade the wires too. I'm in the 'parts gathering' phase at the moment.
Also coming up:
belt tensioner
belt
coolant
that should keep me busy for a couple/few days.
Old May 16, 2023 | 05:21 PM
jamieo's Avatar
jamieo
No gains with any "performance" plugs.Stock are the best option.
Old May 16, 2023 | 06:08 PM
Catfish4818's Avatar
Catfish4818
How many miles on your car? Without referring back to the owner's manual, I believe spark plugs are scheduled for replacement at 100K miles.
Old May 16, 2023 | 08:05 PM
Dcasole's Avatar
Dcasole
Unless u are running a blower , Stock plugs and wires are the best
Dave
Old May 16, 2023 | 10:04 PM
When the time comes, I plan to go with the stock stuff. My car only has 7300 miles on it so should be quite a while until a change is needed.
Old May 16, 2023 | 11:08 PM
Jaykoh-Z51's Avatar
Jaykoh-Z51
Turning 88,000 in a week or so.
I figured stock plugs would be fine. Just wanted to be sure.
Dave, no blower in my ride. Figured I'd put in upgraded wires since I'll be pulling the old ones out anyway.
Old May 17, 2023 | 12:34 AM
Gixxerman's Avatar
Gixxerman
Moderator
St. Jude Donor '18 thru '25
I have friends running 1200hp.. OEM coils and wires.. they are fine no need to throw money at something that's not a problem
Old May 17, 2023 | 06:58 AM
thompstl1's Avatar
thompstl1
I had a plug/wire failure at 23,000 miles on my 2018 Z06 (the misfire code doesn't specify if it's a plug or wire misfiring the mechanic said). So, he replaced both the plug and wire on #5 cylinder. The car ran like a top.. for about 200 miles, then developed another dead miss. This time, it was #6 cylinder. I had all 8 plugs and wires replaced and no problems for about 300 miles now. My neighbor down the street, has a 2016 zo6. Neither of us could believe a failure occurred at that low milage.... Strange was it seems; his car developed a dead miss, and he has about 35,000 miles on his car. His was # 3 cylinder. New plugs and wires solved his problem.
After some investigation we learned that some Corvette mechanics believe there was a "batch" of bad wires installed on C7's. Most appear to be on the Z06 models, or perhaps something about Z06's make the wires fail prematurely (not often, but on some cars).
I went with stock wires/plugs because I didn't know at the time about the speculative issue of there being weak factory wires on some cars. My friend (who used a renowned Corvette mechanic here in Houston) went with upgraded aftermarket wires and NGK plugs.
Not sure this situation applies to you or to most others for that matter, but it is a couple of data points for you to consider.
Old May 17, 2023 | 07:51 AM
449er's Avatar
449er
CF Community Team
Dave
OEM is good quality
Old May 17, 2023 | 09:06 AM
Jaykoh-Z51's Avatar
Jaykoh-Z51
OEM plugs it is.
I was going to get wires from Granatelli with red insulation sleeves. It would compliment the engine dress up I already have.
Old May 17, 2023 | 09:12 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Originally Posted by Jaykoh-Z51
OEM plugs it is.
You have chosen well grasshopper! I do think there are "performance parts" for the GM sold by GM that are red in color. I did that on my 98 Camaro and they looked purdy.
Elmer
Old May 17, 2023 | 10:11 AM
DoubleG's Avatar
DoubleG
Why should stock plugs not be used with a blower, may I ask?
Old May 17, 2023 | 11:10 AM
Gearhead Jim's Avatar
Gearhead Jim
St. Jude Donor '13
One Corvette tech told me that at 50k miles the plugs are fine, at 100k they definitely need changed.
Sounds like you're at a good change point.
To spark plug replacement
