Driver window issue
Old May 29, 2023 | 03:59 PM
Dropit69's Avatar
Dropit69
8th Gear
Default Driver window issue
driver window wont go back up that 3/4 inch or so after closing door anymore..so leaves a gap and it wont do it when you enter car and close door either..but will if you roll window all way up then open door to get out..is this a programing issue?...thanks
Old May 29, 2023 | 04:03 PM
69 L46 4 Speed's Avatar
69 L46 4 Speed
Sounds like you may have had a loss of power. If you haven't done it already try reindexing the widow.
Old May 30, 2023 | 01:58 PM
reindexing may solve the window problem.
Old May 30, 2023 | 05:58 PM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Window Indexing and
Express-Up Reset
Window indexing may be required if
the vehicle battery has been
recharged or disconnected, or is not
working. Express-up and the
convertible top will not function until
the windows are reset. After battery
power is restored, a message or
code displays in the Driver
Information Center. See Driver
Information Center (DIC) on
page 5-23.
Once power is restored:
1. Close the doors.
2. Start the vehicle.
3. Hold the window switch up to the
fully closed position.
Window Indexing and Express-Up Reset
Window indexing may be required if the vehicle battery has been recharged or disconnected, or is not working. Express-up and the convertible top will not function until the windows are reset. After battery power is restored, a message or code displays in the Driver Information Center. See Driver Information Center (DIC) on page 5-23.
1. Close the doors.
3. Put windows down
4. Raise each window and hold the window switch up in the fully closed position for a few seconds after the window is up.
Old May 30, 2023 | 09:38 PM
Dropit69's Avatar
Dropit69
8th Gear
thanks ..yes i did lose power to batt over winter..ill try this friday..appreciate the help..
To Driver window issue
