Just got back into a 2016 C7, so trying to remember how to use the info in the Corvette forum again lol. Almost certain Ive seen this problem posted and asked about before. My AC is working great, except the only ventilation is coming from the floor vents, and the small defogger vents next to each window. I have no ventilation coming from the dash vents in any mode, either heating or cooling. Im remembering a fix (I think, Im old) that explained a way to reset or calibrate the diverter in the dash. Can anyone refresh my memory, point me to the right forum, or has had any experience with this problem? TIA
Sounds like the blend doors on your HVAC system may be working improperly. There have been a number of threads on the forum that discusses this. A search should bring up some hits for you to review.
I had the same issue. It is a big job since you have to remove the dash to get to the diverter. $1000 at the dealer. It is like a $40 part, but labor intensive. I have fixed a lot of issues on my 15 C7, but I wanted no part of this fix so I paid the dealer.
Try un plugging your battery for a few minutes. This may re set it. If that doesn't work you may be able to have the dealer reset the door with a scan tool. If that doesn't work you may need to dis assemble the dash to replace parts. I had this happen to me in February. New blend door and actuator, and blower motor. $4000. Thankfully covered by warranty.
