5w-30
Old Jun 7, 2023 | 10:46 PM
Gunsmokez's Avatar
Gunsmokez
Default 5w-30
Hey just had my oil change done at dealership. First thing I noticed when I got home. Work order says Mobil 1 5w-30 synthetic was used.
I look under hood and cap says sae 0w-40 to be used.
So umm am I in trouble ?
Old Jun 7, 2023 | 10:50 PM
stevettec7's Avatar
stevettec7
Not at all. 5w-30 was what the factory filled the C7’s with until 2019 (I believe that year is correct).0w-40 was formulated by Mobil to allow owners to use the same viscosity for track and street. Then in 2019, Mobil posted a bulletin stating 0w-40 was acceptable in all C7’s. What year is yours?
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
If you don't track it you will be fine per the manual.
Old Jun 7, 2023 | 10:58 PM
Gunsmokez's Avatar
Gunsmokez
mines a 2019
Old Jun 7, 2023 | 11:23 PM
Mad*Max's Avatar
Mad*Max
they should have discussed with you, you should call to ask that they used "dexos 2"
Old Jun 7, 2023 | 11:25 PM
RonC7's Avatar
RonC7
From the 2019 Owner's Manual:
RTFM
Ron
Old Jun 7, 2023 | 11:28 PM
Mad*Max's Avatar
Mad*Max
This is what I used last time:
Old Jun 8, 2023 | 12:14 AM
Gunsmokez's Avatar
Gunsmokez
RTFM
Ron
ya I should be fine. It says mobil 1 5w-30 synthetic. How ever the oils fill dip stick shows a bit too much oil. Slight over the second hash tag! Annoying
Old Jun 8, 2023 | 12:43 AM
aklim's Avatar
aklim
You did allow it a few minutes to drip down and all that before checking, right? If it is slight over, I wouldn't worry. If it is way too much over, worry.
Old Jun 8, 2023 | 02:20 AM
Avanti's Avatar
Avanti
5W-30 was recommended for years, as noted (apart from track use). So, if you use yours exclusively on the street, no concerns.
Old Jun 8, 2023 | 06:25 AM
Jungtfl's Avatar
Jungtfl
I am assuming that Mobil 1 5W-30 Dexos 1 is sufficient over the more expensive ESP?
Old Jun 8, 2023 | 06:35 AM
mdformula350's Avatar
mdformula350
just put in fresh 5w-30 , my engine didnt blow up,
yet........
Old Jun 8, 2023 | 07:02 AM
Tinkertech's Avatar
Tinkertech
Is European formula OK now? I see that is what the bottle says.
Old Jun 8, 2023 | 08:16 AM
sjw91's Avatar
sjw91
Not all of them. It needs to be Dexos approved.
Old Jun 8, 2023 | 08:47 AM
eboggs_jkvl's Avatar
eboggs_jkvl
Moderator emeritus
2015 C7 of the Year Finalist
Sigh...
WHen asking a tech question, tell us what you have, it really helps.
What kind of 2019 do you have? Dry sump or regular? One takes 9.5 quarts the other, 6.5 quarts. One requires a special procedure to read the level of the oil, the other, ram the stick in, pull it out and read it.
So, response?
Elmer
Old Jun 8, 2023 | 09:00 AM
Maxpowers's Avatar
Maxpowers
According to GM dexos approved helps the cats. Not sure why it doesnt do that in Europe lol.
Old Jun 8, 2023 | 09:11 AM
sjw91's Avatar
sjw91
Not really. Dexos applies to several things, including a lower sulfur content to prevent valve deposits. The "Emissions System Protection" designation only applies to diesel engines. The levels of zinc and phosphorus (the things that hurt cats) are nearly the same as the 5w-30. Porsche, Mercedes, BMW, etc all use the European Formula 0w-40, and they don't have issues with cat failures.
To 5w-30
Old Jun 8, 2023 | 10:31 AM
Maxpowers's Avatar
Maxpowers
Thanks for the correction.
Old Jun 8, 2023 | 11:20 AM
AnotherNorskie's Avatar
AnotherNorskie
RTFM
Ron
This surpised me. I always thought Dexos2 was for diesels:
https://vehiclefreak.com/dexos-1-vs-...ich-is-better/
We should be using Dexos gen1, gen2, or gen3.
Old Jun 8, 2023 | 11:35 AM
sjw91's Avatar
sjw91
Kinda gets into corporate politics. They needed a higher HTHS motor oil to be able to handle driving on street and track, but GM's Dexos 1 spec is formulated more for fuel economy. The only other spec they owned at the time was Dexos 2, which was primarily used for diesels, but it fit the requirements. Now they seem to have Dexos D for diesels and Dexos R for performance cars.
Side note: Mobil has a rebate going on right now, and ESP is actually included this year. https://mobilpromotions.us/rebate/
