dtc code question
Old Jun 10, 2023 | 09:30 PM
9sec's Avatar
9sec
Default dtc code question
I have a hard code (unable to clear it) of U0100. can communication code. from what I read it saying the can bus cannot communicate with the ecu. car runs perfectly fine but this stored code bothers me. any ideas on how to fix it? battery disconnect doesn't work code reader delete doesn't work and no idea where to start to look since the car runs perfect.
Old Jun 11, 2023 | 07:50 AM
Tinkertech's Avatar
Tinkertech
Pull the battery cable (-), wait 5 minutes, step on brake peddle, reconnect cable, test.
Kind of like a reboot on a computer.
Old Jun 11, 2023 | 08:11 AM
Dcasole's Avatar
Dcasole
If it's is in history you cannot remove it , some codes will clear by themselves others will stay
I have some history codes that go back to when i dropped a valve
Dave
Old Jun 11, 2023 | 11:57 AM
laserdude2215's Avatar
laserdude2215
Not true. If you have a professional scan tool, you could find the module which is actually generating this message. But if everything is functioning normally, I recommend you just ignore it as it is probably a history code from some transient condition which will clear after 50 ignition cycles.
Old Jun 11, 2023 | 12:25 PM
Dcasole's Avatar
Dcasole
Even GDS2 does not clear my history codes , But as Laserdude states it will show the module that generated the code
I have had some show a module did not boot on startup but after a restart all was fine .... If it is in history I would not worry about it
Dave
Old Jun 11, 2023 | 03:07 PM
Bill Dearborn's Avatar
Bill Dearborn
Unless there is something wrong with the car communication codes don't mean much. There could have been an electrical noise that interrupted a state of health message between two modules and when the signal was retransmitted the interference had disappeared.
Bill
Old Jun 11, 2023 | 06:57 PM
9sec's Avatar
9sec
Bill
everything seems to be running fine. I did have my blower off for a rebuild and port and when I reinstalled it I had both maf and map codes but restarting the car a couple times seems to have cleared them and the check engine light I had. my buddy has a fairly sophisticated scanner and he could only find this 1 code. on his scanner it shows up under the amplifier which I thought was weird
appreciate everyone input for now ill leave it be and enjoy the new ported blower sounds!
To dtc code question
