Downshifting issue?
Old Jun 18, 2023 | 07:55 PM
Chevette!?!?'s Avatar
Chevette!?!?
Default Downshifting issue?
From about 35MPH, I floor my C7 Corvette and it downshifts all the way down to second gear! And it revs to the Moon!
I quickly up shift a couple of gears with the paddles because it sound like the engine will blow if I don't ! Is this normal?! It seems to act better in Manual mode.
Old Jun 18, 2023 | 09:34 PM
Dcasole's Avatar
Dcasole
It should shift at 6,500 ... are u saying it's not shifting
Dave
Old Jun 18, 2023 | 11:21 PM
squirrelchew's Avatar
squirrelchew
When you floor it in the automatic it drops to the lowest available gear? Stop the presses! File a complaint with the NHTSA!
When it "revs to the moon" is it revving beyond redline? Anything at or below redline is fine. Don't be scared.
Old Jun 19, 2023 | 05:22 AM
Chevette!?!?
I think what you are saying is,......that the car is working as designed.
Okay, but it doesn't seem to increase the speed much. This is my first modern sports car and I don't want to damage the engine or transmission.
Old Jun 19, 2023 | 09:40 AM
Chevette!?!?
I'm trying to say that the transmission shifts to a way too low of gear for the speed the car is traveling.
Old Jun 19, 2023 | 09:56 AM
Dcasole's Avatar
Dcasole
when it downshifts what is the RPM that it jumps to . If you can't watch it but you have a PDR , record a run as we will be able to see the MPH and the RPM
Dave
Old Jun 19, 2023 | 10:13 AM
Woodson's Avatar
Woodson
Your rev limiter will prevent you from getting even half way to the moon.
Old Jun 19, 2023 | 10:30 AM
Squeaky Wheel's Avatar
Squeaky Wheel
Have had numerous Vettes C4 through C7. All automatics. I remember the first time I floored the C4. WOW! Had never experienced a downshift like that or that sort of acceleration. Each subsequent generation was even more exhilarating. I don’t do it very often, and only under the most favorable of conditions, but it definitely is rather startling and puts a huge grin on my face. I suspect what you are seeing is perfectly normal.
Old Jun 19, 2023 | 10:34 AM
Power Hawk's Avatar
Power Hawk
This is yet another reason I feel that it is important to be in a Corvette club. You could ask others in the club if their C7 does the same thing. My bet is that it is normal acceleration. I know mine really takes off when I floor it.
Old Jun 19, 2023 | 11:42 AM
The car will downshift to the lowest gear that can safely be used. Unless there is something seriously wrong with your car, it is working as designed.
Old Jun 19, 2023 | 12:10 PM
squirrelchew
What is the specific thing that is making you think it's "way too low" of a gear?
35mph in 2nd gear on the 8 speed automatic is 3200 RPM, or 3600 RPM if you have a Z51.
35mph in 1st gear on the 8 speed automatic is 4850 RPM, or 5500 RPM if you have a Z51.
If you have the 6 speed auto, 35 is 4500RPM in first (4900RPM for Z51) and 2700RPM in second (2850RPM for Z51)
The engine can rev to something like 6800 RPM.
None of the numbers that are supposed to be happening are even remotely close to alarming.
If you're banging off the rev limiter when it's trying to downshift, your transmission is slipping. Otherwise, if you're panicking because it's getting above 2000 rpm... relax, sell your car, and buy a Toyota Camry.
Old Jun 19, 2023 | 02:37 PM
Woodson's Avatar
Woodson
And stay away from sport bikes
To Downshifting issue?
