Help with part number? ✅SOLUTION‼️
Old Jun 19, 2023 | 05:01 PM
Racer1735's Avatar
Racer1735
Default Help with part number? ✅SOLUTION‼️
I’m needing the part number for this screw. It’s one that attaches the air baffle/deflector that attaches above the radiator fan on a ‘14 Stingray. I’m thinking king this particular fastener is used several places. Dropped one when I was removing parts to check my air filter. the screw does not appear to be shown on the parts fiche with the air deflector.
Old Jun 19, 2023 | 05:25 PM
Catfish4818's Avatar
Catfish4818
Can you post a pic of where it goes? That would help.
Old Jun 19, 2023 | 05:31 PM
9sec's Avatar
9sec
any oreillys auto zone has them in the hardware section. fairly common screw
Old Jun 19, 2023 | 10:39 PM
GREENKAR's Avatar
GREENKAR
It is a metric body screw. Any hardware store will carry it,
Old Jun 19, 2023 | 10:46 PM
Racer1735's Avatar
Racer1735
Got what I needed. Thanks guys. Wanted the OEM as it has a washer attached. Didn’t want different head styles either. Got the part number and my local Chevy house had a few of them.
started at O’Reilly’s but they didn’t have the correct size in stock. Same with AutoZone.
but have the correct part and everything is out back together.
Old Jun 20, 2023 | 04:27 AM
So, how about sharing the part number so others that may be looking for similar parts will have a leg up on the search.
Old Jun 20, 2023 | 06:46 AM
stevettec7's Avatar
stevettec7
Default ✅solution‼️
This might be what you’re looking for maybe? I used these on my fenders recently.
https://www.gmwarehousedirect.com/oe...YtMmwtdjgtZ2Fz
Old Jun 21, 2023 | 01:47 AM
96GS#007's Avatar
96GS#007
You can buy a box of 15 via an aftermarket supplier through Amazon for ~$10
LINK LINK
You'd be hard-pressed to tell it's different from OEM without a very hard and up close look. If someone is looking that closely at the bolt, they have other issues.
Can probably find other sources as well that have even better pricing with enough research.
Old Jun 21, 2023 | 06:36 AM
Bills17n72's Avatar
Bills17n72
To Help with part number? ✅SOLUTION‼️
