I would add that even with the valves open cold start is still more aggressive.. to my understanding it has something to do with programming the timing to get the cats hot faster for emissions.
Originally Posted by --Z06--
Care to explain?
^ This is what I have heard too. The loud bark of the exhaust does not last long.
If you have the exhaust set in Track Mode the only time the valves close is when the engine is in 4 cylinder mode. With an M7 you need to be in Eco Mode for the engine to switch or in 5th gear below 35 mph for the valve to close. With an A8 the drive mode can be anything and as long as the transmission is in auto mode the engine will switch. However, when the exhaust is in Track Mode it stays open all the time when the car is idling. When a cold engine is started the fuel flow and timing are set to provide a loud starting noise and then slowly drop off as the engine warms as shown in this video of my car.
^^^^^^^THIS ^^^^^^
Cold start does have a different profile in tune to assist with Cat efficiency on startup
Pulling the NPP fuse will have no affect on the sound produced during cold start
You can set the NPP to be open through the Settings selection. First press the settings that will bring a screen and looking for Driving Mode. Select that and you will now see a screen that has Engine Sound Management. You can then select any of the options listed, but most like to slide down to the final selection which is track. However, this will not keep the valves open all the time, but more the n in the factory setting. If you pull the fuse, they will remain open all the time but as mentioned they will never sound like the cold start. The nice thing about using the Engine Management, if you have fussy neighbors before leaving or coming home you can select Stealth mode and they are closed.
Here is a YouTube video that goes over this.
See, I have a Range device and my NPP is always on Track Mode but I still hear the valves close all the time. Would pulling the fuse still cause a code with the AFM disabler?
Have the mild2wild setup to my garage door switchs 1&2. Mounted in fuse box and have it powered by the heat seater circuit and grounded inside the fuse box. Nothing to get wet and no wires running in the engine compartment. Doing this, the NPP defaults to whatever the last setting was.I generally leave the NPP open all the time unless I want to not offend my neighbors. Turn it off during state inspection so the loader exhaust does not tip the inspector that I have a catless X-pipe. Wiring scheme is some where on the forum. Works great.
No, there's no code if you pull the NPP fuse. But there is a code if you pull the AFM fuse.
