I just purchased a 2014 Corvette and the oil looked perfectly clean however it hadn't been changed for about a year or longer. I changed it within a couple days to keep my mind at peace. Oil is cheap and new engines are expensive.
When I buy a used car, I have a simple rule. It flows, it goes. I don't even bother to look and guess. Not that I can see oxidation.
I've averaged about 4500 miles a year on my 2017. I've changed the oil 1-2 times a year with no issues
Unless you did proper testing, for example, wear characteristics as to whether there was accelerated or decelerated or no change in wear, "no issues" is worthless at best, misleading at worst.
Originally Posted by squirrelchew
I see oil at $23-26/gallon is why I ask.
Not sure where you are seeing oil that high, but that is .
I have always changed my oil once per year as I do not put that many miles on the car. Putting fresh oil in once/year is not that expensive and I know it is properly protected.
1 to 2 Qts more to get the oil level correct from another 5 Qt. jug that was saved from last oil change. Always buy two jugs and save the extra for the next couple of oil changes.
PF64 = ~ $5.
So oil change = ~ $35 - $40.
Oil and filters are cheap and really don't care even if they were 2x the cost. I'm doing it myself the right way.
I’m always surprised by reports of oil looking dirty after only several hundred or even a thousand miles. It shouldn’t, regardless of time. Perhaps the rings are starting to go bad or you often start it without letting the oil get hot, or perhaps the car has been modded in some way that reduces flow (like a catch can) or totally eliminates (like disabling) the PCV system. One of the generally unrecognized but huge benefits of PCV is much greater oil life. Think about it. Without PCV, the vapors within the crankcase are 100% blowby exhaust gas, which is constantly coming into contact with the oil. With PCV, most of the crankcase is just plain old air, sucked in by PCV, with only a dilute amount of blowby exhaust gas. Which do you suppose is harder on the oil? And besides that, PCV is without any close competition, the most important single anti-pollution device on the car, way more important than even the cats. Between the reduced oil life even for just restricting PCV flow, and the vastly increased pollution if you totally disable it, I strongly discourage doing anything that messes with design airflow through the PCV system.
I think you might be missing one part about the PCV. The pistons create the positive pressure, that is then vented to the intake of the engine. In ye olden days the crankcase pressure was vented to atmosphere, but for emissions it is routed to the inlet of engine to be passed through the combustion chamber and exhaust. A PCV system doesn't intake clean air, it is exhausting crankcase pressure (mixture of previously combusted air charge and oil vapor) from out of the crankcase.
Your post is correct up until the last sentence. True, in the bad old days, piston blowby was routed to the atmosphere. Also true, with PCV it is routed to the engine intake. But your statement that PCV doesn’t intake clean air is incorrect. The PCV system does suck in clean air from downstream of the engine air filter. If it did not, the engine vacuum which the PCV valve sees would create a vacuum in the crankcase, which you do not want. So there is a steady flow of filtered air into the crankcase, sucked in by engine vacuum acting on the PCV valve. The ratio of air to piston blowby gases varies, depending on the condition of the rings and hence the amount of blowby. But with rings in good condition, there is typically more air than blowby gas in the crankcase, except of course for wide open throttle operation, where blowby is at its greatest and there is little or no engine vacuum.
I don't think this is true, as there is a check valve aka "PCV Valve" that prevents pulling metered air from the air intake into the engines crankcase. The PCV isn't an intake source for the engine. Crankcase vacuum is highest at open throttle due to the engine drawing air from the PCV. The purpose of the PCV is to create vacuum against the crankcase by using the intake stroke.
If the PCV valve didn't exist, then yes the crankcase could be pulling in air from another source. But this would toss the AFR's since that's air that was metered via the MAF, but no longer in the intake charge.
CPB, the first few sentences of your own reference in post #39 disprove your belief, talking about airflow and a mixture of air and crankcase gases. The PCV valve has two way action which is why it rattles when you shake it. At high vacuum such as idle, the valve body sides to the side of the vacuum, thus limiting airflow when the airflow through the PCV system could otherwise mess up air to fuel ratio at idle. It does not close completely, it simply leaves a very small opening so that flow is small. On the other hand, if pressure in the intake manifold is higher than that of the crankcase such as a backfire, or a super or turbocharged engine at high boost, the valve body slides the other way and can close completely to prevent pressure from being applied to the crankcase. If you don’t believe me, just go look at your engine. Somewhere on a V8, almost always on the bank opposite the PCV valve, there will be a hose that allows air into that rocker cover. That’s the PCV inlet, sometimes called breather. Most of the time, flow in that line goes into the rocker cover and thus crankcase, sweeping the piston bypass into the PCV valve, where the mixture of air and piston blowby gets sucked into the engine by vacuum and gets burned. In those rare cases when the PCV valve slides the other way because intake manifold pressure is higher than crankcase pressure due to backfire, or high boost in a turbo or supercharged engine, flow in that line can be in the other direction. It still gets sucked into the engine, just via the normal intake line rather than the PCV valve. In those cases, the crankcase is indeed pure piston blowby, but as soon as the backfire or high boost passes, flow is the normal air sweeping piston blowby through the PCV valve.
