Build sheet?
Old Jun 27, 2023 | 04:54 PM
Jon-D's Avatar
Jon-D
Default Build sheet?
Found a 2019 GS for sale and in my limited access to vin decoding it appears to be a 2LT, however he claims it has the performance recorder, which I thought only came on the 3LT group. Can someone help me out, it would save a 2 hour drive to look at it. Also, anything I should look for on this year?
1G1YY2D73K5113180
Old Jun 27, 2023 | 04:59 PM
C7nut's Avatar
C7nut
Its standard on a 3LT and optional on the 2 LT.
Old Jun 27, 2023 | 05:09 PM
Let It Ride's Avatar
Let It Ride
I have a 2019 2LT GS with PDR as was said, optional.
Old Jun 27, 2023 | 08:37 PM
RonC7's Avatar
RonC7
If they will take a picture of the label on the driver side door jamb, the QR code is the Service Parts label. Use a QR code app on your phone to get a list of options. Look for I06 (nav) and UQT (pdr). Optional on 1/2LT, standard on 3LT.
Ron
Old Jun 27, 2023 | 10:14 PM
JMills's Avatar
JMills
2023 C2 of the Year Winner - Unmodified
2020 C8 of the Year Winner - Unmodified
2020 C6 of the Year Winner - Unmodified
2020 C2 of the Year Finalist - Unmodified
2017 C2 of the Year Finalist
2016 C2 of the Year Finalist
Find out The build date if before February 2019 ask him if he had the triple flush! If it’s a auto.
Old Jun 27, 2023 | 10:18 PM
Jims Z06's Avatar
Jims Z06
I believe the PDR was one of the more popular options for the 2 LT
Have it on my 2LT
Old Jun 27, 2023 | 11:27 PM
TraceZ's Avatar
TraceZ
Enter a VIN Number to begin.
Search
Show/Hide GM RPO Lookup
Report for..
1G1YY2D73K5113180
Vehicle: Listed Below
Year: 2019
Build Date: 2018-12-10
RPO Description
1SZ PACKAGE OPTION- (1SZ)
2LT PACKAGE LT OPTION 2 "LT" PKG 2(2LT)
5A7 SPARE WHEEL DELETION 5A7)
6X1 COMPONENT FRT LH NON-COMPUTER SEL SUSP SUSP(6X1)
703 Unk.
70I INTERIOR TRIM COLOR (70I)
719 Unk.
7X1 COMPONENT FRT RH NON-COMPUTER SEL SUSP SUSP(7X1)
8X2 COMPONENT RR LH NON-COMPUTER SEL SUSP SUSP(8X2)
9L3 TIRE SPARE DELETE 9L3)
9X2 COMPONENT RR RH NON-COMPUTER SEL SUSP SUSP(9X2)
A2X Unk.
AAB MEMORY DRIVER CONVENIENCE PACKAGE CONVENIENCE PKG(AAB)
AAV Unk.
AG2 ADJUSTER,SEAT,6-WAY POWER,SPLIT BENCH,PASSENGER 6-WAY PWR P/SEAT ADJR(AG2)
AJ7 Unk.
AJK CONTROL SEAT, POWER BOLSTER, POWER LUMBAR POWER LUMBAR & POWER BOLSTER SEAT CONTROL(AJK)
AL0 SENSOR INDICATOR INFLATABLE RESTRAINT, FRT PASS/CHILD PRESENCE DETECTOR FRT PASS/CHILD PRESENCE DETECTOR
INFL REST IND SENSOR(AL0)
AP9 NET,CONVENIENCE CONVENIENCE NET(AP9)
AQ9 SEAT,FRONT BUCKET,DRIVER,PASSENGER,RECLINING RECL FRT BKT ST,LUXURY(AQ9)
AXJ VEHICLE TYPE PASSENGER CAR PASSENGER CAR VEH TYPE(AXJ)
B4Z Unk.
BBT IDENTIFICATION - CELTA CAR PLATFORM-GMB
BGR PLANT CODE - BOWLING GREEN, KY, USA
BTV CONTROL REMOTE ENGINE START REMOTE CONTROL ENGINE START(BTV)
CFA ROOF HATCH, REMOVABLE, CARBON FIBER CARBON FIBER REMOVABLE ROOF HATCH(CFA)
CJ2 HVAC SYSTEM AIR CONDITIONER FRT, AUTO TEMP CONT, AUX TEMP CONT A/C FRT AUTO/AUX CONT(CJ2)
D42 COVER,REAR COMPARTMENT SECURITY(SHADE) R/CMPT SECURITY SHADE(D42)
DD0 MIRROR,O/S,R AND L REM CTL,ELEC,DEFOG,LT SENSITIVE O/S ELEC R/CON MIR(DD0)
DD8 MIRROR,INSIDE,REARVIEW,TILT,AUTOMATIC,LI GHT SENSITIVE I/S RR VIEW MIR,LIGHT SENSITIVE(DD8)
EF7 COUNTRY UNITED STATES OF AMERICA (USA) U S A(EF7)
EFR LOCAL - PACKAGE; GAMMA 1.4 COMFORT H/BACK
EYT ORNAMENTATION EXT EMBLEM, NAMEPLATE, CARBON FLASH, PACKAGE
FE6 SUSPENSION SYSTEM RIDE, HANDLING, PERFORMANCE, VAR 1 PERFORMANCE SUSPENSION(FE6)
FHO VEHICLE FUEL GASOLINE E10 E10 GASOLINE FUEL TYPE(FHO)
G8G PRIMARY COLOR EXTERIOR, ARCTIC WHITE (9567)
G96 AXLE POSITRACTION LIMITED SLIP, ELECTRONIC ELEC POSITRACTION LIMITED SLIP AXLE(G96)
GU2 AXLE,REAR,2.73 RATIO 2.73R(GU2)
I19 ENGINEERING YEAR 2019
IL3 TRIM,INTERIOR DESIGN (IL3)
IO5 RADIO INFOTAINMENT SYSTEM - UPLEVEL WITH CONNECTIVITY UPLEVEL RADIO W/CONNECTIVITY INFOTAINMENT
SYSTEM(IO5)
J56 BRAKE SYSTEM PWR, FRT & RR DISC, ANTILOCK, FRT & RR WHL, HEAVY DUTY HVY DUTY ANTILOCK BRAKES(J56)
J6A CALIPER COLOR BLACK BRAKE CALIPER COLOR(J6A)
KNP COOLING SYSTEM,TRANSMISSION,HEAVY DUTY HVY DUTY TRANS CLG SYS(KNP)
KNR COOLING SYSTEM AXLE AXLE COOLING SYSTEM(KNR)
KQV Unk.
LHD VEHICLE DRIVE LEFTHAND DRIVE LEFT HAND DRIVE(LHD)
LT1 Unk.
M5U TRANSMISSION AUTO 8 SPD, 8L90
MAH MARKETING AREA NORTH AMERICA NORTH AMERICA(MAH)
N38 STEERING COLUMN TILT, TELESCOPING, POWER PWR RETRACTABLE TILT STRG COL(N38)
NK4 Unk.
NPP EXHAUST SYSTEM PERFORMANCE PERF EXH(NPP)
NUE EMISSION SYSTEM CALIFORNIA, LEV160
Q8X WHEEL 19 X 10.0, J, FRT & 20 X 12.0, J, RR, ALUMINUM, DESIGN 12
R9N CONTROL - SALES ITEM NO. 89
6/27/23, 10:21 PM Comprehensive VIN Decoder
RWL CHASSIS REAR WHEEL DRIVE (R.W.D.)
SLM SALES PROCESSING - STOCK ORDERS
T4F HEADLAMPS HIGH INTENSITY DISCHARGE HIGH INTENSITY DISCHARGE HEADLAMPS(T4F)
U2K DIGITAL AUDIO SYSTEM S-BAND DIGITAL S-BAND AUDIO SYS(U2K)
U2L Unk.
UE1 COMMUNICATION SYSTEM VEHICLE, G.P.S. 1 GPS 1 VEH COMM SYS(UE1)
UG1 OPENER GARAGE DOOR, UNIVERSAL UNIVERSAL GARAGE DR OPENER(UG1)
UHS DISPLAY INSTRUMENT DRIVER INFO ENHANCED (MULTI COLOR ENHANCED GRAPHIC ) ENHANCED GRAPHIC DRIVER INFO
DISPLAY(UHS)
UQS SPEAKER SYSTEM PREMIUM AUDIO BRANDED WITH SURROUND AMPLIFIER PREMIUM SPKR SYS W/SURROUND AMP(UQS)
UTJ THEFT DETERENT ELECTRICAL, UNAUTHORIZED ENTRY UNAUTHORIZED ENTRY THEFT DETERENT(UTJ)
UTT THEFT DETERENT BODY SECURITY CONTENT THEFT DETERENT BODY SECURITY CONTENT(UTT)
UTU SENSOR, VEHICLE INCLINATION VEHICLE INCLINE SENSOR(UTU)
UTV SENSOR, VEHICLE INTERIOR MOVEMENT VEHICLE INTERIOR MOVEMENT SENSOR(UTV)
UV6 DISPLAY,HEADUP HEAD UP DISPLAY(UV6)
UVJ CAMERA FRONT VIEW
V03 COOLING SYSTEM,EXTRA CAPACITY EXTRA CAPACITY CLG(V03)
V8D VEHICLE STATEMENT US US VEHICLE STATEMENT(V8D)
VA5 LANGUAGE LABEL(ENGLISH) ENGLISH LANGUAGE LABEL(VA5)
VG6 Unk.
VH9 ENVELOPE,OWNER INFORMATION MANUAL OWNER INFO MAN ENV(VH9)
VHM Unk.
VK3 LICENSE PLATE,FRONT MOUNTING PACKAGE FRT LIC PLT MTG PKG(VK3)
VRG VALUE ADDED ASM COCKPIT VALUE ADDED COCKPIT(VRG)
VRH VALUE ADDED ASM STEERING COLUMN VALUE ADDED STRG COLUMN(VRH)
VRK VALUE ADDED ASM ROOF TRIM UPLEVEL ROOF TRIM(VRK)
VRL VALUE ADDED ASM FRONT HORIZONTAL SUSPENSION HORIZONTAL FRT SUSP UPGRADE(VRL)
VRM VALUE ADDED ASM FRONT VERTICAL SUSPENSION VERT FRT SUSP UPGRADE(VRM)
VRN VALUE ADDED ASM REAR SUSPENSION RR SUSP UPGRADE(VRN)
VRR VALUE ADDED ASM TIRES & WHEELS TIRES & WHEELS UPGRADE(VRR)
VRS VEH PERSONALIZATION CARGO SECURITY SHADE CARGO SECURITY SHADE(VRS)
VT7 OWNERS MANUAL ENGLISH LANGUAGE ENGLISH LANGUAGE OWNERS MANUAL(VT7)
VV4 Unk.
VYW VEH PERSONALIZATION PREMIUM CARPET FLOOR MATS VEH ACCESSORIES PREMIUM CARPET FLR MATS(VYW)
WMK VIN MODEL YEAR 2019
XFK TIRE ALL P285/30ZR19 SL BW RF4 (FRT) P335/25ZR20 SL BW RF4 (REAR)
XL8 FREQUENCIES 433 MHZ 433 MHZ FREQ(XL8)
YF5 CALIFORNIA EMISSION CERTIFICATION CALIFORNIA EMIS CERTIFICATION(YF5)
YM8 IDENTIFICATION LIMITED PERSONALIZATION OPTION (LPO) LIMITED PERSONALIZATION OPTION(LPO)
Z16 APPEARANCE PACKAGE,SPECIAL EDITION SPECIAL EDITION(Z16)
Z52 Unk.
6/27/23, 10:21 PM
Old Jun 27, 2023 | 11:37 PM
TraceZ's Avatar
TraceZ
SYSTEM(IO5)
^^This is the radio without NAV or the Performance Data recorder.
IO6 would be the code if it had NAV/PDR.
Old Jun 28, 2023 | 04:44 AM
Old Jun 28, 2023 | 09:03 AM
69 L46 4 Speed's Avatar
69 L46 4 Speed
Trace Z nailed it. The car you are looking at did not come with the PDR.
Old Jun 28, 2023 | 10:32 AM
Flattman's Avatar
Flattman
Also, isn't "UQT" the RPO code for the PDR as well?
Old Jun 28, 2023 | 10:36 AM
TraceZ's Avatar
TraceZ
Yes.
UQT RECORDER VEHICLE PERFORMANCE
Old Jun 28, 2023 | 10:44 AM
Vette Jockey's Avatar
Vette Jockey
Roadster Madness. 😠
St. Jude Donor '13, '20-'21
What you need is a https://monroneylabels.com/ build sheet. Punch the VIN # in and you can download a copy of the window sheet and see what it was sold with.
I did it for my. Car and it was around eight dollars.
Old Jun 28, 2023 | 10:54 AM
vader86's Avatar
vader86
Optional on 2LT, I have it on my 2019.
Old Jun 28, 2023 | 08:08 PM
Let It Ride
This is how it looks on my 2019 GMVIS report
Old Jul 4, 2023 | 12:29 AM
Jon-D's Avatar
Jon-D
Wow! Thank you everyone!!
Old Jul 4, 2023 | 07:18 AM
449er's Avatar
449er
CF Community Team
Wow, TraceZ sure did a lot of typing there!
To Build sheet?
Old Jul 4, 2023 | 09:59 PM
geewez's Avatar
geewez
Have the seller that a picture of the options sticker on the battery cover board in the rear of the car and email it to you.
Old Oct 19, 2024 | 12:31 PM
Markmbaha1's Avatar
Markmbaha1
Default Missing RPO Code sticker
My 2018 does not have this sticker on the drivers door sill jamn area. Any other locations on the 2018?
Ron
Old Oct 20, 2024 | 10:47 PM
Avanti's Avatar
Avanti
"Wow, TraceZ sure did a lot of typing there!" Have you never copied and pasted?
