Corvette stickers
Old Jun 28, 2023 | 09:26 PM
Coachpec's Avatar
Coachpec
Default Corvette stickers
Does anyone know how much it would cost to have all these stickers taken off? I was told by dealership that they recommend it be taken off by a professional
Old Jun 28, 2023 | 10:12 PM
DrivesWithTwoFeet's Avatar
DrivesWithTwoFeet
It's easy to do it yourself. Pull off at a 90 degree angle and clean any residue with an adhesive remover.
Old Jun 29, 2023 | 12:08 AM
Andy8007's Avatar
Andy8007
Banned Scam/Spammer
What’s wrong with them you don’t like the #8 !!
Old Jun 29, 2023 | 12:28 AM
Avanti's Avatar
Avanti
A little heat... LITTLE... from a hair dryer can help, too. Instead of adhesive remover, I prefer Goo Gone, or liquid car wax, or even WD40 for assorted residues. If you do not have sufficient finger/thumb-nails to do the initial "lifting" recruit someone who does. I've successfully removed stickers and emblems from every vehicle I've owned for years, except for one antique roadster. . Patience and care are the watchwords. All the best.
Old Jun 29, 2023 | 12:36 AM
Guard Dad's Avatar
Guard Dad
My experience suggests that you DO NOT pull them off at a 90 degree angle but at a 180 degree angle. Pulling at a 90 degree angle increases the risk of pulling the paint off the car.
Old Jun 29, 2023 | 01:33 AM
96GS#007's Avatar
96GS#007
If you don't want to do it yourself, figure a couple hundred for a shop to pull the stickers off, remove the residue, and lightly wax the area.
A little heat and then some 3M Adhesive Remover works wonders if you follow the DIY route.
Old Jun 29, 2023 | 02:10 AM
mountainears's Avatar
mountainears
2017 C7 of Year Finalist
Someone went crazy with the flair on that stingray 😳
The non factory stuff will probably come off pretty easy with some heat.
Old Jun 29, 2023 | 04:58 AM
Travlee's Avatar
Travlee
I would be more concerned about removing the rear window louvers
Old Jun 29, 2023 | 05:18 AM
This does sound like a pretty accurate estimate for a shop to do the work. Some of those should definitely come off.
To Corvette stickers
